I am trying to write a GStreamer app in C with two pipelines, each using nvivafilter plugin. There seems to be a problem when sending EOS to one of the pipelines. App crashes with error:
NvEGLImageFromFd: Failed to create EGLImage from dma-buf fd (1047)
What is the proper way to send EOS to one pipeline and have the other continue to play? Advice please.
I have attached a basic example below.
include <gst/gst.h>
include <signal.h>static gboolean recording = FALSE;
static GMainLoop *loop;
static GstElement *pipeline1, *pipeline2;static gboolean
message_cb (GstBus * bus, GstMessage * message, gpointer user_data)
switch (GST_MESSAGE_TYPE (message)) {
case GST_MESSAGE_ERROR:{
GError *err = NULL;
gchar *name, *debug = NULL;name = gst_object_get_path_string (message->src); gst_message_parse_error (message, &err, &debug); g_printerr ("ERROR: from element %s: %s\n", name, err->message); if (debug != NULL) g_printerr ("Additional debug info:\n%s\n", debug); g_error_free (err); g_free (debug); g_free (name); g_main_loop_quit (loop); break; } case GST_MESSAGE_WARNING:{ GError *err = NULL; gchar *name, *debug = NULL; name = gst_object_get_path_string (message->src); gst_message_parse_warning (message, &err, &debug); g_printerr ("ERROR: from element %s: %s\n", name, err->message); if (debug != NULL) g_printerr ("Additional debug info:\n%s\n", debug); g_error_free (err); g_free (debug); g_free (name); break; } case GST_MESSAGE_EOS:{ g_print ("Got EOS\n"); g_main_loop_quit (loop); gst_element_set_state (pipeline1, GST_STATE_NULL); g_main_loop_unref (loop); gst_object_unref (pipeline1); exit(0); break; } default: break;}
return TRUE;
}void startRecording()
GstBus *bus2;
GstMessage *msg2;g_print(“startRecording\n”);
pipeline2 =
gst_parse_launch
(“videotestsrc is-live=true ! nvvidconv ! video/x-raw(memory:NVMM),width=852,height=480 ! nvivafilter customer-lib-name=libnvsample_cudaprocess.so cuda-process=true ! videorate ! nvv4l2h265enc ! h265parse ! qtmux name=muxer ! filesink location=/tmp/cuda.mp4 audiotestsrc is-live=true ! queue ! audioconvert ! audioresample ! avenc_aac ! muxer.”, NULL);gst_element_set_state (pipeline2, GST_STATE_PLAYING);
g_print(“Starting Pipeline2”);
recording = TRUE;bus2 = gst_element_get_bus (pipeline2);
msg2 =
gst_bus_timed_pop_filtered (bus2, GST_CLOCK_TIME_NONE,
GST_MESSAGE_ERROR | GST_MESSAGE_EOS);
if (GST_MESSAGE_TYPE (msg2) == GST_MESSAGE_ERROR) {
g_error (“An error occured with Pipeline2”);
}gst_message_unref (msg2);
gst_object_unref (bus2);
gst_element_set_state (pipeline2, GST_STATE_NULL);
gst_object_unref (pipeline2);}
void stopRecording() {
g_print(“stopRecording\n”);gst_element_send_event(pipeline2, gst_event_new_eos());
recording = FALSE;
}int
sigintHandler(int unused) {
g_print(“You ctrl-c-ed!”);
if (recording)
stopRecording();
else
startRecording();
return 0;
}int
main (int argc, char *argv)
GstBus *bus;
GstMessage *msg;signal(SIGINT, sigintHandler);
/* Initialize Gstreamer */
gst_init (&argc, &argv);/* Build the pipeline */
pipeline1 =
gst_parse_launch
(“videotestsrc is-live=true ! nvvidconv ! video/x-raw(memory:NVMM),width=852,height=480 ! nvivafilter customer-lib-name=libnvsample_cudaprocess.so cuda-process=true ! videorate ! nvv4l2h264enc insert-sps-pps=1 idrinterval=4 ! rtspclientsink location=rtsp://localhost:8554/mystream”, NULL);/* Start playing */
gst_element_set_state (pipeline1, GST_STATE_PLAYING);
startRecording();
g_print(“Starting camera”);
bus = gst_element_get_bus (pipeline1);
msg =
gst_bus_timed_pop_filtered (bus, GST_CLOCK_TIME_NONE,
if (GST_MESSAGE_TYPE (msg) == GST_MESSAGE_ERROR) {
g_error (“An error occured with v4l2”);
}gst_message_unref (msg);
gst_object_unref (bus);
loop = g_main_loop_new(NULL, FALSE);bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline1));
gst_bus_add_signal_watch(bus);
g_signal_connect(G_OBJECT(bus), “message”, G_CALLBACK(message_cb), NULL);return 0;
nviva.c (4.1 KB)
