Accelerated GStreamer text overlay
Can you recommend any solution to display/burn in dynamic text overlay on vide using GStreamer?
We have a very simple pipeline:
nvarguscamerasrc sensor-id=<DCL_SENSOR_ID> sensor-mode=0 gainrange=“1 16” ispdigitalgainrange=“1 1”
! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
! nvvidconv ! textoverlay name=text_overlay ! video/x-raw,format=I420
! nvvidconv ! nvv4l2vp8enc bitrate=8000000 control-rate=1 ! rtpvp8pay mtu=1400 ! udpsink auto-multicast=true clients=<DCL_UDP_SINK_CLIENTS>
where we change the text 5 times in a second and this consumes ~50% of a CPU core on a Nano, but without the text overlay it is below 20%.
Do you have any idea how could we make it more efficient / add less overhead?
Bests,
Peter
You may try this:
Tx2-4g r32.3.1 nvivafilter performance - #16 by DaneLLL
Looks very promising! Thanks!
Im new to CUDA, is this ‘nvivafilter’ will execute the linked code as in case with simple CUDA kernels? Or is there any limitation I should take into account? Based on the example: nvsample_cudaprocess.cu it seems to be.
Also can you point me to a documentation / example where I can see how to pass data between the CPU and GPU? Our use case would be to have a simple C++ app which would receive the events and based on them it should be some updates on the video overlay. So is there any ‘gstreamer’-ish async event based communication or should I use cudaMallocManaged to allocate variables in the shared memory?
Bests,
Peter
Using this approach we now implemented a much more performant solution. Thank you for the suggestion!
But as I’m pretty new to GPU programming the solution itself is a naive solution and Im confident there are lot of room for further improvements.
What Im not sure is how can I profile or debug the nvivafilter. I looked around and the as I see there are very nice tools for such task for standalone CUDA application, nvprof and cuda-memcheck is popping up most of the time. However can I use this with GStreamer and if yes how? Or is there any other alternative to gain performance insights from the nvivafilter?
I think that native profiling on Jetson is on stand-by for now.
You may use host side tools such as nsight for getting GPU stats. Someone else would better advise.
I see :( its a bummer it looked to be a very useful tool.
But my question would still apply for these Nsight tools as well. Can these tools be used to profile CUDA code when it is referenced from a GStreamer pipeline as a shared library?
You may create a new topic for this as it gets far from original title ;-)
For anyone getting here, here are some modified files from public_sources/nvsample_cuda_process:
nvsample_cudaprocess.cu (6.5 KB)
Makefile (5.0 KB)
This may still require some clean up work for avoiding some fault when closing…
gst-launch-1.0 nvarguscamerasrc num-buffers=300 ! nvivafilter customer-lib-name="libnvsample_cudaprocess.so" post-process=true ! 'video/x-raw(memory:NVMM),format=RGBA' ! nvvidconv ! nvoverlaysink
Hi!
Sorry for the late response!
Thank you for the code examples! In the meantime I created a solution for the text overlay based on this:
https://github.com/dusty-nv/jetson-video/blob/master/cuda/cudaFont.cu
Not as flexible as the one you mentioned, but I guess it will cut it for now.
So my last remaining question would be how can I profile these applications.
But you are right it is getting diverged from the current topic :D so I created a new one:
Thanks for the help!
Hi Honey_Patouceul
when compile your nvsample_cudaprocess.cu code with make command, customer_functions.h is not recognized.
Can you help me to find this header file?
fatal error: customer_functions.h: No such file or directory
Ty.
