Gst-nvivafilter
I want to use the video from my Raspberry Pi camera in CUDA.
In this document it says you can use a gstreamer pipeline to do this:
https://developer.download.nvidia.com/embedded/L4T/r32_Release_v1.0/Docs/Accelerated_GStreamer_User_Guide.pdf
The command line it says to run is this:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)30/1’ ! nvivafilter cuda-process=true customer-lib-name=“libnvsample_cudaprocess.so” ! ‘video/x-raw(memory:NVMM), format=(string)NV12’ ! nvoverlaysink -e
However when I run this command line, nothing happens on screen. It just produces this output in the console and nothing else seems to happen:
nano@jetson-nano:~$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)30/1' ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! nvoverlaysink -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 5
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Please can someone help me to get the gstreamer CUDA demo working? Thanks.
A few things that may help:
  • customer-lib-name=“libnvsample_cudaprocess.so”
    if you are not running the command in a directory where such lib exists, it would silently fall back to default version of the lib /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so.
  • You would download the public sources and get this plugin sources. Then you would be able to build your own customer lib defining your custom CUDA processing and give its path to nvivafilter plugin.
  • For using opencv CUDA with nvivafilter, you may find some examples and information from here.
Apparently nvoverlaysink is out of date so I should not have used that.
At this link it specifies a different command to use:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/accelerated_gstreamer.html#wwpID0EXHA
However, the command they say to use does not work either!!!
gst-launch-1.0 nvarguscamerasrc ! \
  'video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, \
  format=(string)NV12, framerate=(fraction)30/1' ! \
  nvivafilter cuda-process=true \
  customer-lib-name="libnvsample_cudaprocess.so" ! \
Does not work. :-(
Just checked now, it does work (tested on NX devkit, I have no Nano).
Does your camera provide 3840x2160@30 ? You may just try:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), format=(string)NV12, framerate=(fraction)30/1' ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! nvoverlaysink -e
that should produce a green rectangle near top left corner.
nvoverlaysink would only work with a local display, not remotely.
What works on NX does not work on Nano in this case.
nano@jetson-nano:~$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), format=(string)NV12, framerate=(fraction)30/1' ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! nvoverlaysink -e
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
And there is no video or popup window.
It seems running… my guess would be that you are using a DP monitor, while nvoverlaysink expects hdmi by default. You would try setting display-id property of nvoverlaysink :
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), format=(string)NV12, framerate=(fraction)30/1' ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! nvoverlaysink display-id=1 -e
Thank you, that fixed it.
