Hi all,
I have successfully been writing a CUDA process that modifies video coming in from the included MIPI camera, using the following command:
gst-launch-1.0 nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)I420, framerate=(fraction)30/1' ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)RGBA' ! nvoverlaysink display-id=0 -e
I wanted to manipulate the pixels in RGB, so I discovered that just adding “format=(string)RGBA” toward the end there seems to work. I can also scale the image there. The RGBA and the scaling seem to happen before input to the libnvsample_cudaprocess, even though it’s listed afterward in the gstreamer pipeline. Could someone explain why this works?
Now I would like to make this work with a v4l2src (usb webcam) source. I’m not sure if it is a video format issue, or if this is just not supported yet. I get the following error:
gst-launch-1.0 v4l2src device=/dev/video0 ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)RGBA' ! nvoverlaysink display-id=0 -e
Setting pipeline to PAUSED ...
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason error (-5)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Any assistance would be appreciated. Thanks!
