I am trying to stream a GMSL camera that is connected to my Xavier NX through a deserializer to USB3 board.
The camera shows up on the list of devices, nvarguscamerasrc does not see the device so I tried with v4l2src but I can’t seem to find a gstreamer command that lets me stream it.
This is the camera information that I can retrieve:
$ v4l2-ctl -d /dev/video3 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Size: Discrete 1936x1100
Interval: Discrete 0.033s (30.000 fps)
WARNING: erroneous pipeline: could not link v4l2src0 to videoconvert0, neither element can handle caps video/x-raw, format=(string)YUYV, width=(int)1936, height=(int)1100, framerate=(fraction)30/1
I tried using only a few of the caps but the result is the same.
The only thing that worked so far for me is this command:
It still doesn’t work. It’s even weirder now, none of the commands that I used before work. Gstreamer opens a window but there is nothing in it, only a sort of “screenshot” of my desktop. There is no error message shown on the terminal and it stops only when I interrupt with Ctrl-C
You may post the output of failing commands for better advice. Add -v (verbose) to gst-launch-1.0 so that it tells what it is trying.
Is any of video0 to 2 another USB camera ? If yes, you may try without other USB cam.
Check with lsusb -t what speed gets your camera, when booting with or pluging after boot.
You may also try to use io-mode=2 as v4l2src plugin property.
