Gst-launch-1.0 nvarguscamerasrc can works but not with v4l2src plugin
Hi
My platform infomation:
Sensor:LI IMX390_GMSL2 [IMX390 + MAX9295A, without ISP] — MAX9296A — AGX Xavier
BSP L4T 32.5.0, with my own driver
The gst-launch-1.0 command with nvarguscamerasrc plugin can works, also can get camera preview, the command is as below:
gst-launch-1.0 \
    nvarguscamerasrc sensor-id=0 \
    ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1' \
    ! nvoverlaysink
but it not works with v4l2src plugin ,the command is as blow:
gst-launch-1.0 \
    v4l2src device="/dev/video0" \
    ! video/x-raw, width=1920, height=1080, format=YUY2, framerate=30/1 \
    ! xvimagesink
And the error message is :
The source looks to be a Bayer sensor. Please run
$ v4l2-ctl --list-formats-ext
to get more information. If it does not support YUYV, you are not able to launch it through v4l2src.
