Nvv4l2camerasrc not working
@ShaneCCC
I made a custom driver which is working with the following two pipelines
 gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! xvimagesink
v4l2-ctl --device /dev/video0 --stream-mmap --stream-to=frame.raw --stream-count=1 --set-ctrl bypass_mode=0
but when I try to work with the following pipeline I am not getting video
 gst-launch-1.0 nvv4l2camerasrc ! nvvidconv ! nvoverlaysink
the error I get is
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.089173590
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
The dmesg log is
dmesg.log (3.5 KB)
Kindly someone help me figure out this issue.
Thanks in Advance.
Suppose nvv4l2camerasrc and v4l2src don’t support Bayer raw output.
