Problem in gst-lanuch-1.0 streaming
hi,
I am developing my own camera.
I can use v4l2-ctl to grab single image by below command:
$ v4l2-ctl --set-fmt-video=width=1280,height=1024,pixelformat=RG8 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw -d /dev/video0
but when I try gst-launch-1.0 it runs in error as below.
$gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw,format=GRAY8,width=1280,height=1024,framerate=30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=I420’ ! nvoverlaysink
Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Setting pipeline to PLAYING ... New clock: GstSystemClock ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error. Additional debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.000240518 Setting pipeline to PAUSED ... Setting pipeline to READY ... Setting pipeline to NULL ... Freeing pipeline ...
Any suggestion?
Thanks,
hal
Please refer to
You would need to have the driver ready first.
hi DaneLL,
I have followed the instructions in the sensor driver programming instruction, and also gone through my codes with IMX219’s code, but I can’t find any issue.
So far I can stream video by gst-launch-1.0 v4l2src,
Here is error message when running gst-launch-1.0 nvarguscamerasrc:
$ gst-launch-1.0 -v nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=(int)1280, height=(int)1024,format=(string)NV12, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw, format=(string)BGRx’ ! videoconvert ! appsink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)1024, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)1024, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)1024, framerate=(fraction)30/1, format=(string)BGRx
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)1024, framerate=(fraction)30/1, format=(string)BGRx
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)1024, framerate=(fraction)30/1, format=(string)BGRx
/GstPipeline:pipeline0/GstAppSink:appsink0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)1024, framerate=(fraction)30/1, format=(string)BGRx
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)1024, framerate=(fraction)30/1, format=(string)BGRx
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)1024, framerate=(fraction)30/1, format=(string)BGRx
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)1024, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)1024, format=(string)NV12, framerate=(fraction)30/1
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.099728458
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Is there comannd to dump driver or DT’s configuration then check what is missing or wrong?
Note: this relates to Opencv streaming issue
Thanks,
hal.
Please check
hi DaneLLL,
Looks like this is same issue I reported in Opencv streaming issue. Let’s close this case, and discuss in that thread.
Thanks,
hal.
