Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason not-negotiated (-4)
Execution ended after 0:00:00.000241251
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
nvidia@tegra-ubuntu:~$
i would suggest you sharing the fixes or information,
and please accept the answers to let other developer to understand this discussion thread already have a solution,
thanks
root@jetson-xavier-nx-devkit:~# gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, format=(string)UYVY, width=(int)640, height=(int)480, framerate=(fraction)30/1’ ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Pipeline is PREROLLED …
…/gstreamer-1.18.1/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to PLAYING …
Execution ended after 0:00:00.000374947
Setting pipeline to NULL …
Freeing pipeline …
root@jetson-xavier-nx-devkit:~# XDG_RUNTIME_DIR=/run/user/0 gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, format=(string)UYVY, width=(int)640, height=(int)480, framerate=(fraction)30/1’ ! waylandsink
Execution ended after 0:00:00.000819335
Freeing pipeline …
I am using a imx219 camera, which shows up as /dev/video0.
I am developing YOLO/SSD models (jetson-inference and tensorrt_demos repositories), both unable to work with v4l2src pipe, neither any gstreamer command works so far.
The reason I want to use v4l2src is the fact that I want to use v4l2loopback to create a copy device so that I can use same camera for two seperate applications simultaneously.
