[b]
I am trying to capture data from a YUV image sensor connected to the Jetson TX2. I am writing my own driver.
I am able to capture an image using:[/b]
nvidia@tegra-ubuntu:~$ v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --set-ctrl bypass_mode=0 --stream-mmap --stream-count=3 --stream-to=imx334.raw -d /dev/video0
[b]
I can look at the image output in an image viewer and it looks good! correct resolution.
However, I want to stream this data… But, when I run the following command (below) I get the following error message.[/b]
nvidia@tegra-ubuntu:~$ gst-launch-1.0 -v v4l2src ! “video/x-raw” ! videoconvert ! autovideosink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device ‘/dev/video0’ cannot capture in the specified format
Additional debug info:
gstv4l2object.c(3482): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Tried to capture in YU12, but device returned format YUYV
Execution ended after 0:00:00.001255315
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
[b]
How can I get the v4l2src to capture with expected data format of YUYV?
gst-device-monitor-1.0 returns this portion for the camera module input:
[/b]
Device found:
name : vi-output, imx324 2-001a
class : Video/Source
caps : video/x-raw, format=(string)I420, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)[ 16, 16384 ], height=(int)[ 32, 32768 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1;
video/x-raw, format=(string)YV12, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)[ 16, 16384 ], height=(int)[ 32, 32768 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1;
video/x-raw, format=(string)BGR, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)[ 16, 16384 ], height=(int)[ 32, 32768 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)sRGB;
video/x-raw, format=(string)RGB, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)[ 16, 16384 ], height=(int)[ 32, 32768 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)sRGB;
properties:
udev-probed = true
device.bus_path = platform-15700000.vi
sysfs.path = /sys/devices/13e10000.host1x/15700000.vi/video4linux/video0
device.subsystem = video4linux
device.product.name = "vi-output\,\ imx324\ 2-001a"
device.capabilities = :capture:
device.api = v4l2
device.path = /dev/video0
v4l2.device.driver = tegra-video
v4l2.device.card = "vi-output\,\ imx324\ 2-001a"
v4l2.device.bus_info = platform:15700000.vi:0
v4l2.device.version = 263206 (0x00040426)
v4l2.device.capabilities = 2233466881 (0x85200001)
v4l2.device.device_caps = 85983233 (0x05200001)
nvidia@tegra-ubuntu:~$ gst-device-monitor-1.0
[b]
Where is device monitor finding these device capabilities? I can’t seem to find where they are defined in the rootfs…
I find it especially confusing that it is expecting YV12 when I am stating in the device tree and driver that the media format is YUV 2x8.
Thanks for any help you can recommend me.
[/b]
Regards,
Daniel
