Im building a Gstreamer based application on Jetson Nano where we are using nvivafilter to overlay real-time data on the video feed. I a newbie in CUDA and in GPU programing, so I guess there would be lot opportunities to make the current solution more performant. So my question would be: how can I profile my code?
This is our pipeline:
gst-launch-1.0 -e
nvarguscamerasrc sensor-id=“$SENSOR_ID” sensor-mode=0 gainrange=“1 16” ispdigitalgainrange=“1 1” name=“${APP_NAME}pipeline_overrides${SENSOR_ID}”
! “video/x-raw(memory:NVMM), width=(int)${capture_width}, height=(int)${capture_height}, format=(string)NV12, framerate=(fraction)${capture_framerate}/1”
! nvvidconv ! nvivafilter cuda-process=true customer-lib-name=“$customer_lib” ! ‘video/x-raw(memory:NVMM), format=(string)NV12’
! nvvidconv ! nvv4l2vp8enc bitrate=“${capture_bitrate}” control-rate=1 ! rtpvp8pay mtu=1400
! udpsink auto-multicast=true clients=“${udp_clients}”
Where I would like get insights from the ‘nvivafilter’ element.
As a naive solution I checked the output of top and jtop to check the CPU, GPU and memory usages but its not that accurate.
I also tried with some remote debugging (starting the connection from MacOS) with visual profiler, Nsight Systems and Nsight Compute but I was not able to connect to the Jetson.
The visual profiler gives me the following error on startup:
!ENTRY org.eclipse.osgi 4 0 2021-05-24 16:33:53.658
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application “com.nvidia.viper.application.application” could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.birt.report.engine.ReportExecutor, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.ui.ide.workbench.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
The Nsight systems:
DirectoryNotFoundError (150) {
OriginalExceptionClass: N5boost16exception_detail10clone_implIN11QuadDCommon26DirectoryNotFoundExceptionEEE
OriginalFile: /Users/devtools/buildAgent/work/20a3cfcd1c25021d/QuadD/Host/Analysis/PosixDeviceValidator.cpp
OriginalLine: 26
OriginalFunction: bool QuadDAnalysis::PosixDeviceValidator::CheckHostSupport(const QuadDAnalysis::DevicePtr &)
Filename: /Applications/NVIDIA Nsight Systems.app/Contents/target-linux-armv8
ErrorText: Deploy directory does not exist
}Missing directory with target binaries:
/Applications/NVIDIA Nsight Systems.app/Contents/target-linux-armv8NVIDIA Nsight Systems
2021.2.1.58-642947b OSX
- falcon@falcondev.devices:
[Error] Target is not supported.
This version of Nsight Systems does not support profiling on the selected target.
And finally the Nsight Compute is able to connect to the remote but it is stuck with this message:
Trying to connect to process…
Searching for attachable processes on falcondev.devices:49152-49215…
But maybe Im on a wrong track, I mean Im not even sure if any of these tools would work for me as my CUDA code is compiled to a shared lib and will be called by the nvivafilter from a Gstreamer pipeline.
Do you have any recommendation what would be the best way to profile the application?
Bests,
Peter
