Good day
I am using the tracker plugin within my deepstream application and I would like to know if there is a way for me to access more detailed information about the tracked objects. I know that I can find out what the tracked ID’s of the objects are, but I would like to design a probe that will help the program at reassigning lost ID’s. For example, if a object has received an ID, but then gets obstructed for a extended period of time, then the tracker eventually removes the ID. When the objects returns in the frame, then a new ID is assigned to the object-which is a very understandable error. So I want to access information such as ‘deleted ids’ and ‘newly assigned ids’. Is there a way for my to do so because this link does not seem to contain information about how to access the information that I am looking for. I am using deepstream 6.3.
