Deepstream 6.2 Trakcer Ids with multiple streams
does deepstream assign different tracker ids in different streams ? or for all streams, the ids start from 0?
say object_id 1,2,3 and 4 were detected in stream1, and then some object appears in stream2; so will this newly detected object in stream2 will get tracker_id/object_id of 5 ? or it will start from 0??
My use case requires me to have unique tracker/object ids with no overlap whatsoever. is that possible ? or I need to map with stream id ?
• DeepStream Version
• TensorRT Version
Deepstream 6.2 dGPU
It will be 5 for stream2. please also check useUniqueID: 1 in: Gst-nvtracker — DeepStream documentation
