I am encountering a confusing problem when creating programs from a ptx file. Sadly, my current project isn’t in any sort of version control and I’ve changed a bit too much since it last worked (restructuring), so it’s hard to say what introduced it. The function calls that are giving me the problem never gave any issues before, though.
When creating programs from a ptx file using the C++ API (so ContextObj::createProgramFromPTXFile) I get an access violation. However, this only happens on some calls of this function, not all.
This is on Windows 7 64-bit using OptiX 3.9.0 with CUDA 7.5. GPU is a 970, driver 364.72 (I just updated to try to fix this, the problem already existed on the previous driver).
Relevant code snippet below. The error occurs on the last of these four calls. I am sure all four Program objects are declared and all four programs exist by the correct name in the .cu file.
ignore_hit = cont->createProgramFromPTXFile(pars.ptx_dir + "hitprogs.cu.ptx", "ignore_hit");
terminate_hit = cont->createProgramFromPTXFile(pars.ptx_dir + "hitprogs.cu.ptx", "terminate_on_hit");
done_hit = cont->createProgramFromPTXFile(pars.ptx_dir + "hitprogs.cu.ptx", "ray_done");
rec_hit = cont->createProgramFromPTXFile(pars.ptx_dir + "hitprogs.cu.ptx", "receiver_hit");
Output:
First-chance exception at 0x000007FEE2682EF3 (optix.1.dll) in a.exe: 0xC0000005: Access violation reading location 0x0000000000000030.
OAC trace (with paths stripped):
6
64
Platform: Windows
CUDA driver version: 8000
OptiX Version:[3.9.0] Build Number:[20240475Branch%] CUDA Version:[7.5] 64-bit 2015-12-09
Command line: a.exe
Capture time: 2016-04-13 10:45:54
rtContextCreate( 00000000001AF870 )
res = 0
hdl = 0000000000757140
rtContextSetRayTypeCount( 0000000000757140, 2 )
res = 0
rtContextSetEntryPointCount( 0000000000757140, 1 )
res = 0
rtProgramCreateFromPTXFile( 0000000000757140, C:\...\ptx\raygen.cu.ptx, raygen, 00000000001AF898 )
file = oac.ptx.000000.potx
res = 0
hdl = 00000000066ADAA0
rtContextSetRayGenerationProgram( 0000000000757140, 0, 00000000066ADAA0 )
res = 0
rtContextQueryVariable( 0000000000757140, ray_openangle, 00000000001AF7F8 )
res = 0
rtContextDeclareVariable( 0000000000757140, ray_openangle, 00000000001AF7F8 )
res = 0
hdl = 000000000083BB70
rtVariableSet1f( 000000000083BB70, 0.000174533 )
res = 0
rtContextQueryVariable( 0000000000757140, tx_pos, 00000000001AF7F8 )
res = 0
rtContextDeclareVariable( 0000000000757140, tx_pos, 00000000001AF7F8 )
res = 0
hdl = 000000000083BC70
rtVariableSet3fv( 000000000083BC70, 00000000001AF900 )
val = 100 0 0
res = 0
rtContextQueryVariable( 0000000000757140, tx_normal, 00000000001AF7F8 )
res = 0
rtContextDeclareVariable( 0000000000757140, tx_normal, 00000000001AF7F8 )
res = 0
hdl = 000000000083BD70
rtVariableSet3fv( 000000000083BD70, 00000000001AF900 )
val = -1 0 0
res = 0
rtContextQueryVariable( 0000000000757140, tx_pol, 00000000001AF7F8 )
res = 0
rtContextDeclareVariable( 0000000000757140, tx_pol, 00000000001AF7F8 )
res = 0
hdl = 000000000083BE70
rtVariableSet3fv( 000000000083BE70, 00000000001AF900 )
val = 0 0 1
res = 0
rtContextQueryVariable( 0000000000757140, tx_k, 00000000001AF7F8 )
res = 0
rtContextDeclareVariable( 0000000000757140, tx_k, 00000000001AF7F8 )
res = 0
hdl = 000000000083BF70
rtVariableSet1f( 000000000083BF70, 1611.07 )
res = 0
rtProgramCreateFromPTXFile( 0000000000757140, C:\...\ptx\hitprogs.cu.ptx, ignore_hit, 00000000001AF898 )
file = oac.ptx.000001.potx
res = 0
hdl = 0000000006B5D040
rtProgramCreateFromPTXFile( 0000000000757140, C:\...\ptx\hitprogs.cu.ptx, terminate_on_hit, 00000000001AF898 )
res = 0
hdl = 0000000006B5D110
rtProgramCreateFromPTXFile( 0000000000757140, C:\...\ptx\hitprogs.cu.ptx, ray_done, 00000000001AF898 )
res = 0
hdl = 0000000006B5D1E0
rtProgramCreateFromPTXFile( 0000000000757140, C:\...\ptx\hitprogs.cu.ptx, receiver_hit, 00000000001AF898 )
