Here is the CUDA (v6) code which I am trying to compile but I am getting this error. Any help is greatly appreciated:
error MSB3721: The command ““E:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.0\bin\nvcc.exe” -gencode=arch=compute_20,code=“sm_20,compute_20” --use-local-env --cl-version 2012 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin” -I"E:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.0\include” -I./ -I…/…/common/inc -I"E:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.0\include" -I"E:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.0\include" -G --keep-dir Debug -maxrregcount=0 --machine 32 --compile -cudart static -g -DWIN32 -D_DEBUG -D_CONSOLE -D_CRT_SECURE_NO_WARNINGS -D"-D_SCL_SECURE_NO_WARNINGS" -DNOMINMAX -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o Debug\SubGP.cu.obj “C:\SubGP.cu”” exited with code -1.
here is the code:
#include <optix.h>
#include <optix_world.h>
using namespace optix;
// Payload for ray type 0: gamma rays
struct GammaPL
int recursion_depth;
// Payload for ray type 1: visible rays
struct VisiblePL
int primID;
rtDeclareVariable(uint2, launch_index2, rtLaunchIndex, );
rtDeclareVariable(uint, launch_index1, rtLaunchIndex, );
rtDeclareVariable(Ray, curRay, rtCurrentRay, );
rtDeclareVariable(GammaPL, gammaPL, rtPayload, );
rtDeclareVariable(VisiblePL, visiblePL, rtPayload, );
rtDeclareVariable(rtObject, top_object, , );
rtDeclareVariable(int, hitPrimID, attribute hitPrimID, );
rtBuffer<UCHAR, 2> Intersection;
rtBuffer<int, 1> HitCount;
rtBuffer<float3, 1> Guards;
rtBuffer<float3, 1> InteriorGuards;
rtBuffer<float3, 1> OptVertices;
rtBuffer<uint3, 1> OptTriangles;
RT_PROGRAM void CountHits()
float3 origin = Guards[launch_index1];
float3 direction = make_float3(1, 1, 1);
Ray ray = make_Ray(origin, direction, 0, 0.0001f, RT_DEFAULT_MAX);
GammaPL payload;
payload.recursion_depth = 0;
rtTrace(top_object, ray, payload);
HitCount[launch_index1] = payload.recursion_depth;
RT_PROGRAM void Visibility()
float3 origin = InteriorGuards[launch_index2.y];
float3 v0 = OptVertices[OptTriangles[launch_index2.x].x];
float3 v1 = OptVertices[OptTriangles[launch_index2.x].y];
float3 v2 = OptVertices[OptTriangles[launch_index2.x].z];
float3 centroid = (v0 + v1 + v2) / 3;
float3 direction = centroid - origin;
Ray ray = make_Ray(origin, direction, 1, 0.0001f, RT_DEFAULT_MAX);
VisiblePL payload;
payload.primID = ‘o’;
if(payload.primID == launch_index2.x)
Intersection[launch_index2] = ‘x’;
RT_PROGRAM void ExceptionIntersectionCheck()
const unsigned int code = rtGetExceptionCode();
if( code == RT_EXCEPTION_STACK_OVERFLOW )
Intersection[launch_index2] = ‘-’;
else
rtPrintExceptionDetails();
RT_PROGRAM void ExceptionInteriorCheck()
HitCount[launch_index1] = -1;
else
RT_PROGRAM void intersection_program(int prim_index)
float3 v0 = OptVertices[OptTriangles[prim_index].x];
float3 v1 = OptVertices[OptTriangles[prim_index].y];
float3 v2 = OptVertices[OptTriangles[prim_index].z];
float3 v0v1 = v1 - v0;
float3 v0v2 = v2 - v0;
float3 normal = cross(v0v1, v0v2);
float3 secondPointOnRay = curRay.origin + 5.0 * curRay.direction;
float3 raySeg = secondPointOnRay - curRay.origin;
// Check if the line is parallel to plane
if(dot(normal, raySeg) != 0)
// Compute plane-line intersection (http://mathworld.wolfram.com/Line-PlaneIntersection.html)
Matrix4x4* num = new Matrix4x4();
num->setCol(0, make_float4(1, v0));
num->setCol(1, make_float4(1, v1));
num->setCol(2, make_float4(1, v2));
num->setCol(3, make_float4(1, curRay.origin));
Matrix4x4* den = new Matrix4x4();
den->setCol(0, make_float4(1, v0));
den->setCol(1, make_float4(1, v1));
den->setCol(2, make_float4(1, v2));
den->setCol(3, make_float4(0, raySeg));
float t = -(num->det() / den->det());
float3 intersection = lerp(curRay.origin, secondPointOnRay, t);
// Check if point lies in primitive (barycenter approach)
float area2 = dot(v0v1, v0v2);
float u = dot(v1 - intersection, v2 - intersection) / area2;
float v = dot(v2 - intersection, v0 - intersection) / area2;
if(u > 0.0 && v > 0.0 && u + v <= 1.0 && t > 0.0)
float hit_distance = length(intersection - curRay.origin);
if(rtPotentialIntersection(hit_distance))
hitPrimID = prim_index;
rtReportIntersection(0);
RT_PROGRAM void bounding_box_program(int prim_index, float result[6])
result[0] = fminf(fminf(v0.x, v1.x), v2.x);
result[1] = fminf(fminf(v0.y, v1.y), v2.y);
result[2] = fminf(fminf(v0.z, v1.z), v2.z);
result[3] = fmaxf(fmaxf(v0.x, v1.x), v2.x);
result[4] = fmaxf(fmaxf(v0.y, v1.y), v2.y);
result[5] = fmaxf(fmaxf(v0.z, v1.z), v2.z);
RT_PROGRAM void closest_hit_program()
visiblePL.primID = hitPrimID;
RT_PROGRAM void any_hit_program()
gammaPL.recursion_depth++;
rtIgnoreIntersection();
