Hi i tried using Python for GPIO pins accessing and it’s working fine but I’m able to achieve upto KHz range but i want to achieve above 1MHz.
hello nerellasureshkumar7,
please refer to Topic 1049116 about Python GPIO support.
thanks
Related topics
| Jetson Nano 2GB dev kit GPIO toggle speed from Python? | 5 | 1485 | October 5, 2021 | |
| Need 16Mhz frequency on jetson nano GPIO pin | 1 | 838 | August 18, 2021 | |
| GPIO code execution speed increase | 16 | 2337 | June 18, 2021 | |
| Expansion Header in Jetson Nano expansion header | 5 | 725 | August 22, 2022 | |
| What is the Max Input Frequency supported by J41 header GPIO pins? | 10 | 3246 | July 8, 2019 | |
| How to read gpio pins at a high frequency (15kHz) using Python? | 5 | 1125 | July 28, 2022 | |
| Python library for HX711 Jetson Nano | 5 | 3052 | March 24, 2022 | |
| How to modify GPIO's toggle speed | 11 | 1255 | July 21, 2023 | |
| how can we change the frequency of GPIO to 20Khz? | 1 | 453 | September 11, 2019 | |
| PWM Frequency Upper Limitation with Jetson.GPIO | 6 | 7121 | August 28, 2020 |
