Accessing nvds_buf_surface
Is this the proper way to make an OpenCV mat from a buffer, e.g. within a probe handing?
surface = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
frame = np.array(surface, copy=True, order='C')
frame = cv2.cvtColor(frame, cv2.COLOR_RGBA2BGRA)
Disregard please. Found this sample
Hmm. That crashes here:
My pipeline (parameters removed for clarity):
                nvstreammux !
                nvinfer  !
                nvtracker !
                nvvideoconvert !
                video/x-raw(memory:NVMM), format=RGBA !
                nvdsosd !
                nvvideoconvert !
                nvv4l2h264enc !
                rtspclientsink
                uridecodebin  !
                mux.sink_0
The probe is placed at the output sink pad of nvdosd. In the callback I’m running this once for 30 frames (taken from the sample):
    n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
    # convert python array into numpy array format in the copy mode.
    frame_copy = np.array(n_frame, copy=True, order='C')
    cv2.imwrite('./test.jpg', frame_copy)
The only line, which doesn’t crash the entire script with segmentation fault is the first
The next line crashes.
What can I do to narrow down the problem?
The nice thing about this is: With this segfault in the Python script I am now at the same point where I stopped in my Golang script, because I could not avoid the segfault when accessing the surface…
Oh, turns out the addition of nvbuf-memory-type=3 to nvstreammux and the two nvvideoconverts was helpful :)
