Segmentation fault when extracting the frame using a probe
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
**• Language ** Python
I get a segmentation fault error when extracting frames from a multi-stream input pipeline using a probe. Complete code to reproduce this issue is attached herewith (refer test.py)
probe code is as follows :
def osd_sink_pad_buffer_probe(pad, info, u_data):
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    if not batch_meta:
        return Gst.PadProbeReturn.OK
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        print("iterating frames..............")
        try:
        except StopIteration:
            continue
        l_obj = frame_meta.obj_meta_list
        n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
        frame_copy = np.array(n_frame, copy=True, order='C')
        frame_copy  = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGR)
        while l_obj is not None:
            try:
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                continue
            pass
            try:
                l_obj = l_obj.next
                break
        try:
            l_frame = l_frame.next
            break
pipeline code is as follows :
Gst.init(None)
pipeline = Gst.Pipeline()
video_list = ['file:///workdir/test.h264',
                    'file:///workdir/test.h264']
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
streammux.set_property("batched-push-timeout", 25000)
streammux.set_property("batch-size", 30)
streammux.set_property("gpu_id", GPU_ID)
pipeline.add(streammux)
streammux.set_property("live-source", 1)   # need to check
for  id, uri in enumerate(video_list):
    print("Creating source_bin ",uri," \n ")
    #Create first source bin and add to pipeline
    source_bin= create_uridecode_bin((id, uri))
    if not source_bin:
        sys.stderr.write("Failed to create source bin. Exiting. \n")
        sys.exit(1)
    pipeline.add(source_bin)
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
sink = Gst.ElementFactory.make("fakesink", "fakesink")
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
pgie.set_property('config-file-path', "model_config.txt")
pgie.set_property("gpu_id", GPU_ID)
pgie.set_property("batch-size",MAX_SOURCE)
nvvidconv.set_property("gpu_id", GPU_ID)
nvosd.set_property("gpu_id", GPU_ID)
print("Adding elements to Pipeline \n")
pipeline.add(pgie)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(sink)
the problem is with frame extraction I assume
test.py (5.8 KB)
Also, can you tell me the most efficient way to extract frames from a multistream input pipeline, with demux plugin or without it?
Can you share the config file and stream cause crash ?
Use your code with dstest1_pgie_config.txt here
and use sample stream
/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
It’s can run success.
i am still getting segmentation faults with the config and video URL shared by @junshengy , I think the way I extract frames using a probe is not right
Can you check the driver/cuda/trt version ?
nvidia-smi for driver version
nvcc -V for cuda version
dpkg -l | grep nvinfer for trt version
Can you try this sample first ?
This version is recommended
the versions are as follows
Driver Version: 525.105.17 CUDA Version: 12.0
Cuda compilation tools, release 11.5, V11.5.119
Build cuda_11.5.r11.5/compiler.30672275_0
the sample code worked fine
I know where the problem is .You can upgrade the cuda version.
1.Add caps filter after nvvidconv before nvosd,like this.
caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter = Gst.ElementFactory.make("capsfilter", "filter")
if not filter:
    sys.stderr.write(" Unable to get the caps filter1 \n")
filter.set_property("caps", caps)
modify color format to
frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGRA)
2.Use cuda unified memory
if not is_aarch64():
    # Use CUDA unified memory in the pipeline so frames
    # can be easily accessed on CPU in Python.
    mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
    streammux.set_property("nvbuf-memory-type", mem_type)
    nvvidconv.set_property("nvbuf-memory-type", mem_type)
Please refer to the sample code.
