Deepstream python kafka+rtsp save the detection frame Segmentation fault (core dumped)
**• Hardware Platform ** GPU
• DeepStream Version 6.3
**• NVIDIA GPU Driver Version (valid for GPU only)**A4000
I am try to run deepstream python with kafka and rtsp out pipeline with save image but when i add
n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
n_frame = crop_object(n_frame, obj_meta)
frame_copy = np.array(n_frame, copy=True, order=‘C’)
frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGRA)
img_path = "frame
{}.jpg". format(frame_number)
cv2.imwrite(img_path, frame_copy)
got a Segmentation fault (core dumped)
This line, when an array converted to np.array, gets an error.
Can you please solve this error in the in the pipeline?
pipeline.txt (17.2 KB)
please refer to this ready-made code.
Yes, I’m referring to this code. When I convert the array to a numpy array, I get a segmentation fault error.
thank you issue has been resolve i am not set nvvidconv1.set_property(“nvbuf-memory-type”, mem_type)
property
