Unfortunately, other topics have come up lately, so I am just getting back to it now.
Last I opened a thread on this topic here: Accurate RGB color output via HDMI on Jetson TX2 - Jetson & Embedded Systems / Jetson TX2 - NVIDIA Developer Forums
In response to my request, you suggested the following post: Full range RGB strange behavior on Nvidia Jetson AGX Xavier Developer Kit - #23 by cdsousa
We tried changing these parameters, but this did not result in accurate color output for us.
In following the results:
The right axis represents the expected RGB value, the left axis represents the received:
We started with xorg.conf set to Limited ColorRange:
Default - CMU_Enable 1, Force User Degamma 0
Suggested in post - CMU_Enable 0, Force User Degamma 1
Then with xorg.conf set to Full ColorRange
Suggested in post -CMU_Enable 0, Force User Degamma 1
We also tried the others Parameter combinations (CMU_Enable 1, Force User Degamma 1 and CMU_Enable 0, Force User Degamma 0)
Do you have another proposal?
Best regards
Michael
