jrtt
January 18, 2018, 5:58pm
1
In Nvidia Jetson TX2 using HDMI, it seems to only be able to display a limited range (16-235) instead of the full range (0-255).
I saw the same question for TX1 on:
but couldn’t find anything about TX2.
How can I have RGB full range in HDMI for the TX2?
Hi jrtt,
It should be set to full range by default. Could you try following configuration?
with xorg.conf –
Section "Screen"
Identifier "Default Screen"
Monitor "HDMI-0"
Option "ColorRange" "Full"
EndSection
Full range got selected(0 to 255).
with xorg.conf –
Section "Screen"
Monitor "HDMI-0"
Option "ColorRange" "Limited"
EndSection
Limited range got selected. (16 to 235)
jrtt
January 19, 2018, 4:10pm
3
We modified xorg.conf to set ColorRange for Full or Limited and didn’t saw any difference between the two.
Configuration used:
# Disable extensions not useful on Tegra.
Section "Module"
Disable "dri"
SubSection "extmod"
Option "omit xfree86-dga"
EndSubSection
EndSection
Section "Device"
Identifier "Tegra0"
Driver "nvidia"
# Allow X server to be started even if no display devices are connected.
Option "AllowEmptyInitialConfiguration" "true"
EndSection
# RGB Limited fix
Section "Screen"
Monitor "HDMI-0"
EndSection
Is this configuration correct? If so, what else can be causing this issue?
Hi jrtt,
Which BSP are you using? Also, I think you are sure your monitor has full range RGB support, right?
Could you paste the display edid?
jrtt
January 23, 2018, 1:41pm
5
Hi WayneWWW,
We rechecked the pipeline, and TX2 is sending full range by default. The issue was in the video input for TX2 that was being acquired with RGB limited range. I fixed that and is working fine now.
Thank you very much for your support.
