[ACE] Linux Support for NvAudio2FaceMark Plugin (Audio2Face-3D Local Execution)
I’m using the NvAudio2FaceMark plugin (v3.0) for Audio2Face-3D local execution in Unreal Engine 5.6. It currently only supports Windows (Win64).
Is there a Linux version available? If not, can you provide the Linux binaries (.so files) needed for local A2F execution on Ubuntu?
I have the base NV_ACE_Reference plugin working on Linux for remote execution, but need local execution support.
Hi there @sankara,
I am not aware that there are pre-built versions available for Linux. Since A2F was open sourced not too long ago you should have everything available to try and build yourself, as you did with the reference plugin.
But I am not an expert, so if this doesn’t help I suggest you check out the Discord server where most of the ACE/A2F discussions take place now.
