Recently my laptop ubuntu system is crashed. After I reinstall the Ubuntu 24.04, I can not install the Audio2Face in the Omniverse env. Can you please let me know how to install the Audio2Face program?
@jqin2014 i am just another user, and A2F should be open source now and can be downloaded:
@Simplychenable, thanks for your great information. Since there are so many A2F can be downloaded, I am not sure which one I should use? My previous working one is the linux version. Can you please let me which one you are using? Thanks a lot.
i am not a frequent user of A2F, so i would defer any specifics to the devs on the Discord community. in the discord server below, you will find ace-digital-humans channel where you could get some support such as installation/setup:
that said, i believe you need the SDK at the minimum, which you can read about how to compile the app on the github repo. but other packages comes down to whether those are required in your use case or need examples/samples to use as a point of reference. below is a breakdown outlined in the NVIDIA blog ( NVIDIA Open Sources Audio2Face Animation Model | NVIDIA Technical Blog ):
@Simplychenable, Thanks. I will look into it.
A2F the app, has been depreciated. Along with Launcher. A2F, the NIM and plugin, is still alive, but we do not support it here on this Forum.
