Audio2Face cannot be launched
I want to launch audio2face app with omniverse launcher, but the app cannot be launched. Then I check the launcher.log and run the audio2face.sh manually, the log is displayed as follows.
[libra@localhost audio2face-2023.2.0]$ ./audio2face.sh
[Info] [carb] Logging to file: /home/libra/.nvidia-omniverse/logs/Kit/Audio2Face/2023.0/kit_20231213_150922.log
2023-12-13 07:09:22 [2ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.modifier.titlebar-105.1.1+105] Built using kit version: 105. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
[0.196s] [ext: omni.kit.async_engine-0.0.0] startup
[0.373s] [ext: omni.assets.plugins-0.0.0] startup
[0.387s] [ext: omni.stats-0.0.0] startup
[0.392s] [ext: omni.client-1.0.1] startup
[0.416s] [ext: omni.gpu_foundation-0.0.0] startup
[0.490s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.491s] [ext: carb.windowing.plugins-1.0.0] startup
[0.551s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-12-13 07:09:23 [1,080ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) UHD Graphics 630 (CFL GT2)
| Driver Version: 535.104.05 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 2080 Ti | Yes: 0 | | 11510 MB | 10de | 0 |
| | | | | | 1e04 | 72222647… |
| | | | | | 1 | |
| 1 | Intel(R) UHD Graphics 630 (CFL… | | | 23787 MB | 8086 | 0 |
| | | | | | 3e98 | 8680983e… |
| | | | | | 0 | |
| OS: 8 centos, Version: 8.00.1, Kernel: 4.18.0-513.el8.x86_64
| XServer Vendor: The X.Org Foundation, XServer Version: 12011000 (1.20.11.0)
| Processor: Intel(R) Core™ i7-9700K CPU @ 3.60GHz | Cores: 8 | Logical: 8
| Total Memory (MB): 31717 | Free Memory: 26175
| Total Page/Swap (MB): 16067 | Free Page/Swap: 16067
2023-12-13 07:09:24 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-12-13 07:09:24 [79ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into ‘/home/libra/.local/share/ov/data/Kit/Audio2Face/2023.0/ed2b1aa5-b7f7-4391-78b36b8b-f63d367e.dmp.zip’ for upload.
‘crashreport.gui’ exited with code 1272023-12-13 07:09:24 [189ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/home/libra/.local/share/ov/data/Kit/Audio2Face/2023.0/ed2b1aa5-b7f7-4391-78b36b8b-f63d367e.dmp.zip’
2023-12-13 07:09:24 [235ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:‘/home/libra/.local/share/ov/data/Kit/Audio2Face/2023.0/ed2b1aa5-b7f7-4391-78b36b8b-f63d367e.dmp.zip’ svr:‘https://services.nvidia.com/submit
2023-12-13 07:09:24 [268ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2023-12-13 07:09:24 [293ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘158.1+release158.tc9390.1f134350’
2023-12-13 07:09:24 [326ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Wed Dec 13 07:09:24 2023 GMT’
2023-12-13 07:09:24 [351ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2023-12-13 07:09:24 [376ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘ed2b1aa5-b7f7-4391-78b36b8b-f63d367e’
2023-12-13 07:09:24 [410ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2023-12-13 07:09:24 [443ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/home/libra/.local/share/ov/data/Kit/Audio2Face/2023.0/ed2b1aa5-b7f7-4391-78b36b8b-f63d367e.py.txt’’
2023-12-13 07:09:24 [476ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2023-12-13 07:09:24 [510ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1702451362’
2023-12-13 07:09:24 [543ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2023-12-13 07:09:24 [732ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘2’
2023-12-13 07:09:25 [985ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2023-12-13 07:09:25 [1,018ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 127’
2023-12-13 07:09:25 [1,051ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘105.1+release.132354.c677816d.tc’
2023-12-13 07:09:25 [1,110ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2023-12-13 07:09:25 [1,135ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2023-12-13 07:09:25 [1,168ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2023-12-13 07:09:25 [1,202ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2022.2’
2023-12-13 07:09:25 [1,235ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Audio2Face’
2023-12-13 07:09:25 [1,268ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘startup’
2023-12-13 07:09:25 [1,302ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘2023.0.0’
2023-12-13 07:09:25 [1,327ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2023-12-13 07:09:25 [1,360ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘release’
2023-12-13 07:09:25 [1,394ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘tc’
2023-12-13 07:09:25 [1,427ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘c677816d’
2023-12-13 07:09:25 [1,460ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildId = ‘18309665’
2023-12-13 07:09:25 [1,494ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘105’
2023-12-13 07:09:25 [1,527ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘1’
2023-12-13 07:09:25 [1,560ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMr = ‘0’
2023-12-13 07:09:25 [1,594ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘132354’
2023-12-13 07:09:25 [1,627ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘0’
2023-12-13 07:09:25 [1,660ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘105.1.0’
2023-12-13 07:09:25 [1,694ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘./kit/kit ./apps/audio2face.kit’
2023-12-13 07:09:25 [1,727ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘default’
2023-12-13 07:09:25 [1,760ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 25.2319/30.9739GB, Swap: 15.6914/15.6914GB, VM: 1.71799e+10/1.71799e+10GB’
2023-12-13 07:09:25 [1,794ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = 'Wed Dec 13 15:09:23 2023
| NVIDIA-SMI 535.104.05 Driver Version: 535.104.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 2080 Ti Off | 00000000:01:00.0 On | N/A |
| 26% 35C P8 29W / 250W | 230MiB / 11264MiB | 8% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2907 G …/Xorg 87MiB |
| 0 N/A N/A 3035 G …/gnome-shell 111MiB |
| 0 N/A N/A 3673 G …ures=SpareRendererForSitePerProcess 27MiB |
2023-12-13 07:09:25 [1,835ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
2023-12-13 07:09:25 [1,869ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| | | | | | 1e04 | 72222647… |
| | | | | | 1 | |
| | | | | | 3e98 | 8680983e… |
| | | | | | 0 | |
2023-12-13 07:09:25 [1,902ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘1973962950529005779’
2023-12-13 07:09:25 [1,936ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2023-12-13 07:09:26 [1,969ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
2023-12-13 07:09:26 [2,002ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/home//.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967’
2023-12-13 07:09:26 [2,036ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2023-12-13 07:09:26 [2,069ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] upload_file_minidump = ‘/home/libra/.local/share/ov/data/Kit/Audio2Face/2023.0/ed2b1aa5-b7f7-4391-78b36b8b-f63d367e.dmp.zip’
Segmentation fault (核心已转储)
@ustcshen i am just another user passing by - it looks like you have two drivers installed and could cause some issues with the app. could you try removing the non-RTX driver and try again?
also, if you could upload the most recent Launcher log file in its entirety as an attachment, it’ll help the mods/devs troubleshoot.
It’s definitely worth trying what @Simplychenable suggested. But I believe only Ubuntu ( preferably 22) is officially supported by Audio2Face.
Looks like an OS version issue.
It works fine when I change the machine’s OS to ubuntu20.04.
Thanks @Ehsan.HM
