Audio2Face Not Launching After Changing GPU
Hello! I recently bought an NVIDIA RTX 3090 and connected it to my computer through an eGPU enclosure. I have installed the latest drivers for the GPU from NVIDIA, and it seems to work well. However, Audio2Face does not work with the new GPU. Audio2Face successfully launches when I disconnect the GPU, but it crashes when the new GPU is connected. I have tried reinstalling Omniverse Launcher and Audio2Face, disabling the other GPU in device manager, installing the CUDA toolkit, etc. but I am still running into the issue. Here is the output when I try to launch audio2face.bat from the command line:
C:\Users\USER\AppData\Local\ov\pkg\audio2face-2023.2.0>audio2face.bat
Loading user config located at: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2/user.config.json’
[Info] [carb] Logging to file: C:/Users/USER/.nvidia-omniverse/logs/Kit/Audio2Face/2023.2/kit_20231213_050320.log
2023-12-13 10:03:20 [44ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\c311b151-3f41-4c8f-9259-79fe9ff5a17c.dmp.zip’
2023-12-13 10:03:20 [47ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\86cac7da-522d-4b3c-ac11-6a2e0c2acaff.dmp.zip’
2023-12-13 10:03:20 [53ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\f796d555-4e29-49ec-b225-5730199b79a4.dmp.zip’
2023-12-13 10:03:20 [57ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\95d2a70c-9610-4f62-be92-e82b0a560898.dmp.zip’
2023-12-13 10:03:20 [62ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\4d891464-7991-45df-ba9a-50f122763f5d.dmp.zip’
2023-12-13 10:03:20 [112ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\b12a8c9b-1e91-431a-9353-b4c338259195.dmp.zip’
2023-12-13 10:03:20 [154ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\8a4866c7-3f16-4bbf-8894-25fe8ff4af86.dmp.zip’
2023-12-13 10:03:20 [156ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\7f673877-b79f-498f-ab1b-565df22dbaf4.dmp.zip’
2023-12-13 10:03:20 [161ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\210df073-e94e-47bb-b653-d6ed88a2f9ff.dmp.zip’
2023-12-13 10:03:20 [167ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\f87f3009-f690-4c8b-b964-6f8358ad8dba.dmp.zip’
2023-12-13 10:03:20 [171ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\f63db549-28bc-4ac3-9d01-898a9ffd6067.dmp.zip’
2023-12-13 10:03:20 [175ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\acc62b83-dba7-4408-8aac-98e23a2625a8.dmp.zip’
2023-12-13 10:03:20 [181ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\6f3e6eed-da3a-4612-a3e6-9c21ae9a2025.dmp.zip’
2023-12-13 10:03:20 [184ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\3a01c222-7216-4160-b2c3-4c08a81f651a.dmp.zip’
2023-12-13 10:03:20 [185ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\a6cc7c35-22e4-4c26-96ed-18ac9830c4f8.dmp.zip’
[0.869s] [ext: omni.kit.async_engine-0.0.0] startup
[2.265s] [ext: omni.assets.plugins-0.0.0] startup
[2.304s] [ext: omni.stats-0.0.0] startup
[2.325s] [ext: omni.client-1.0.1] startup
[2.419s] [ext: omni.gpu_foundation-0.0.0] startup
[2.541s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[2.569s] [ext: omni.rtx.shadercache.d3d12-1.0.0] startup
[2.592s] [ext: carb.windowing.plugins-1.0.0] startup
[2.852s] [ext: omni.kit.renderer.init-0.0.0] startup
[2.856s] [ext: omni.kit.window.splash-1.0.1] startup
[3.029s] [ext: omni.kit.agent-0.1.7] startup
[3.055s] [ext: omni.kit.splash-0.4.2] startup
[3.101s] [ext: omni.kit.pipapi-0.0.0] startup
[3.121s] [ext: omni.kit.pip_archive-0.0.0] startup
[3.146s] [ext: omni.mtlx-0.1.0] startup
[3.186s] [ext: omni.usd.config-1.0.3] startup
[3.394s] [ext: omni.gpucompute.plugins-0.0.0] startup
[3.417s] [ext: omni.usd.libs-1.0.0] startup
[3.901s] [ext: omni.services.pip_archive-0.7.0] startup
[3.937s] [ext: omni.kit.loop-default-0.2.0] startup
[3.958s] [ext: omni.kit.test-0.0.0] startup
2023-12-13 10:03:25 [4,500ms] [Warning] [carb.graphics-direct3d.plugin] Aftermath D3D12 failed to initialize.
[4.653s] [ext: omni.usd.schema.semantics-0.0.0] startup
[5.079s] [ext: omni.usd.schema.audio-0.0.0] startup
[5.117s] [ext: omni.usd_resolver-1.0.1] startup
[5.163s] [ext: omni.iray.libs-0.0.0] startup
| Driver Version: 546.12 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 3090 | Yes: 0 | | 24340 MB | 10de | ba8b2f00… |
| | | | | | 2204 | 0 |
| | | | | | 45 | |
| OS: Windows 11 Pro, Version: 10.0 (22H2), Build: 22621, Kernel: 10.0.22621.2861
| Processor: Intel(R) Core™ i7-8850H CPU @ 2.60GHz | Cores: 6 | Logical: 12
| Total Memory (MB): 48694 | Free Memory: 35936
| Total Page/Swap (MB): 59958 | Free Page/Swap: 46272
2023-12-13 10:03:25 [5,161ms] [Error] [carb.graphics-direct3d.plugin] SetNvShaderExtnSlotSpace() failed for slot: 9999, space: 0. status: -1
[5.370s] [ext: omni.volume-0.4.0] startup
[5.427s] [ext: omni.usd.core-1.1.8] startup
[5.444s] [ext: omni.mdl.neuraylib-0.2.0] startup
[5.473s] [ext: omni.hydra.rtx-0.1.0] startup
2023-12-13 10:03:26 [5,589ms] [Error] [carb.graphics-direct3d.plugin] HRESULT: 0xffffffff
2023-12-13 10:03:26 [5,590ms] [Error] [carb.graphics-direct3d.plugin] CreateHeap failed.
2023-12-13 10:03:26 [5,591ms] [Error] [gpu.foundation.plugin] Texture creation failed for the device: 0.
2023-12-13 10:03:26 [5,592ms] [Error] [gpu.foundation.plugin] rtx::resourcemanager::Context::init error: Creating placeholder textures failed.
2023-12-13 10:03:26 [5,593ms] [Error] [gpu.foundation.plugin] Failed to initialize ResourceManager.
2023-12-13 10:03:26 [5,602ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices!
[5.770s] [ext: omni.hydra.iray-0.1.0] startup
[5.792s] [ext: omni.kit.telemetry-0.5.0] startup
[5.883s] [ext: omni.appwindow-1.1.5] startup
[5.928s] [ext: omni.kit.renderer.core-0.0.0] startup
[5.954s] [ext: omni.kit.renderer.capture-0.0.0] startup
[5.975s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[6.069s] [ext: carb.audio-0.1.0] startup
[6.083s] [ext: omni.ui-2.18.3] startup
[6.151s] [ext: omni.uiaudio-1.0.0] startup
[6.157s] [ext: omni.kit.mainwindow-1.0.1] startup
[6.177s] [ext: omni.kit.uiapp-0.0.0] startup
[6.183s] [ext: omni.usd.schema.physics-0.0.0] startup
[6.268s] [ext: omni.usd.schema.anim-0.0.0] startup
[6.295s] [ext: omni.usd.schema.physx-0.0.0] startup
[6.330s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[6.339s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[6.352s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[6.366s] [ext: omni.resourcemonitor-105.0.0] startup
[6.376s] [ext: omni.kit.actions.core-1.0.0] startup
[6.407s] [ext: omni.graph.exec-0.3.0] startup
[6.427s] [ext: omni.kit.commands-1.4.6] startup
[6.463s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[6.489s] [ext: omni.activity.core-1.0.1] startup
[6.521s] [ext: omni.kit.window.popup_dialog-2.0.23] startup
[6.553s] [ext: omni.hydra.usdrt_delegate-7.2.33] startup
[6.585s] [ext: omni.kit.widget.nucleus_connector-1.1.4] startup
[6.611s] [ext: omni.timeline-1.0.9] startup
[6.633s] [ext: omni.kit.exec.core-0.5.0] startup
[6.654s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[6.660s] [ext: omni.usd-1.10.18] startup
[6.782s] [ext: omni.kit.asset_converter-2.1.1] startup
[6.824s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[6.831s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[6.851s] [ext: omni.ui.scene-1.6.16] startup
[6.893s] [ext: omni.kit.usd.layers-2.1.26] startup
[6.971s] [ext: omni.kit.widget.options_menu-1.0.5] startup
[7.006s] [ext: omni.kit.widget.versioning-1.4.5] startup
[7.056s] [ext: omni.kit.widget.filter-1.1.2] startup
[7.077s] [ext: omni.kit.hotkeys.core-1.3.0] startup
[7.106s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[7.121s] [ext: omni.kit.helper.file_utils-0.1.6] startup
[7.278s] [ext: omni.kit.search_core-1.0.5] startup
[7.293s] [ext: omni.kit.widget.filebrowser-2.3.35] startup
[7.342s] [ext: omni.kit.widget.path_field-2.0.8] startup
[7.351s] [ext: omni.kit.menu.utils-1.5.6] startup
[7.400s] [ext: omni.kit.notification_manager-1.0.6] startup
[7.425s] [ext: omni.kit.widget.search_delegate-1.0.4] startup
[7.447s] [ext: omni.kit.widget.browser_bar-2.0.8] startup
[7.467s] [ext: omni.kit.clipboard-1.0.3] startup
[7.489s] [ext: omni.kit.primitive.mesh-1.0.15] startup
[7.546s] [ext: omni.kit.window.filepicker-2.10.9] startup
[7.643s] [ext: omni.kit.stage_templates-1.1.20] startup
[7.671s] [ext: omni.kit.window.file_importer-1.0.21] startup
[7.702s] [ext: omni.kit.window.file_exporter-1.0.22] startup
[7.718s] [ext: omni.kit.window.drop_support-1.0.1] startup
[7.732s] [ext: omni.kit.menu.create-1.0.11] startup
[7.758s] [ext: omni.kit.window.file-1.3.44] startup
[7.787s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[7.790s] [ext: omni.kit.context_menu-1.6.8] startup
[7.806s] [ext: omni.kit.window.content_browser-2.7.17] startup
2023-12-13 10:03:28 [7,692ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Content *********************
2023-12-13 10:03:28 [7,693ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Content” from omni.kit.window.content_browser.extension uses onclick_fn
2023-12-13 10:03:28 [7,694ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
2023-12-13 10:03:28 [7,698ms] [Error] [omni.kit.imgui_renderer.plugin] _prepareDefaultWindow: invalid device attached to the default window!
2023-12-13 10:03:28 [7,712ms] [Error] [omni.ui.python] TypeError: unsupported operand type(s) for +: ‘NoneType’ and ‘int’
At:
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.widget.browser_bar/omni/kit/widget/browser_bar/widget.py(114): _build_ui
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.widget.browser_bar/omni/kit/widget/browser_bar/widget.py(65): init
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/tool_bar.py(52): _build_ui
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/tool_bar.py(68): _build_ui
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/tool_bar.py(41): init
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/tool_bar.py(47): init
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/widget.py(68): _build_tool_bar
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/widget.py(270): _build_ui
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/widget.py(173): init
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/widget.py(58): init
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/window.py(44): _build_ui
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/window.py(23): init
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/extension.py(92): show_window
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/extension.py(58): on_startup
c:\users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/kernel/py\omni\ext_impl_internal.py(164): startup_ext
c:\users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/kernel/py\carb\profiler_init
.py(83): wrapper
c:\users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/kernel/py\omni\ext_impl_internal.py(224): startup
c:\users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/kernel/py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
[7.863s] [ext: omni.kit.widget.stage-2.9.5] startup
[7.912s] [ext: omni.kit.widget.prompt-1.0.6] startup
[7.931s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[7.949s] [ext: omni.kit.widget.searchfield-1.1.3] startup
[7.964s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[7.967s] [ext: omni.kit.widget.settings-1.0.6] startup
[7.971s] [ext: omni.kit.collaboration.presence_layer-1.0.8] startup
[7.977s] [ext: omni.kit.window.property-1.9.6] startup
[7.986s] [ext: omni.kit.window.preferences-1.3.23] startup
[7.998s] [ext: omni.kit.widget.live_session_management-1.2.22] startup
[8.012s] [ext: omni.kit.property.usd-3.21.15] startup
[8.051s] [ext: omni.hydra.engine.stats-1.0.1] startup
[8.056s] [ext: omni.graph.tools-1.41.3] startup
[8.111s] [ext: omni.inspect-1.0.1] startup
[8.121s] [ext: omni.hydra.pxr-1.1.5] startup
[8.151s] [ext: omni.graph.core-2.139.12] startup
[8.177s] [ext: omni.kit.hydra_texture-1.1.11] startup
[8.185s] [ext: omni.kit.viewport.legacy_gizmos-1.0.14] startup
[8.208s] [ext: omni.mdl-0.1.2] startup
[8.296s] [ext: omni.kit.widget.viewport-105.1.6] startup
[8.319s] [ext: omni.kit.viewport.registry-104.0.5] startup
[8.322s] [ext: omni.kit.material.library-1.3.41] startup
[8.361s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[8.384s] [ext: omni.kit.viewport.window-105.1.9] startup
[8.488s] [ext: usdrt.scenegraph-7.2.33] startup
[8.845s] [ext: omni.kit.usd_undo-0.1.2] startup
[8.854s] [ext: omni.kit.viewport.utility-1.0.16] startup
[8.866s] [ext: omni.graph-1.106.1] startup
[9.241s] [ext: omni.kit.widget.graph-1.8.4] startup
[9.291s] [ext: omni.ui_query-1.1.1] startup
[9.305s] [ext: omni.kit.window.extensions-1.3.0] startup
[9.386s] [ext: omni.debugdraw-0.1.2] startup
[9.426s] [ext: omni.graph.ui-1.48.0] startup
[9.556s] [ext: omni.services.facilities.base-1.0.4] startup
[9.584s] [ext: omni.graph.action-1.55.1] startup
[9.819s] [ext: omni.graph.nodes-1.106.3] startup
[10.806s] [ext: omni.services.core-1.7.0] startup
[11.100s] [ext: omni.graph.io-1.5.1] startup
2023-12-13 10:03:31 [10,966ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [omni::fabric::IFabricUsd v0.2] (plugin: ), by client: omni.graph.io.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[11.129s] [ext: omni.anim.shared.core-105.9.1] startup
[11.237s] [ext: omni.graph.ui_nodes-1.5.10] startup
[11.596s] [ext: omni.audio2face.utility-105.1.0] startup
[11.638s] [ext: omni.deform.shared-105.9.2] startup
[11.736s] [ext: omni.graph.bundle.action-2.0.6] startup
[11.741s] [ext: omni.kit.usd.collect-2.2.6] startup
[11.778s] [ext: omni.audio2face.common-105.3.1] startup
[11.836s] [ext: omni.audio2face.player_deps-105.1.1] startup
[11.856s] [ext: omni.kit.tool.collect-2.2.3] startup
[11.896s] [ext: omni.kit.collaboration.selection_outline-1.0.5] startup
[11.935s] [ext: omni.rtx.window.settings-0.6.9] startup
[11.985s] [ext: omni.kit.ui_test-1.2.13] startup
[12.009s] [ext: omni.anim.shared.ui-105.0.2] startup
[12.039s] [ext: omni.iray.settings.core-0.6.4] startup
[12.071s] [ext: omni.deform.ui-105.3.6] startup
[12.133s] [ext: omni.kit.widget.layers-1.6.30] startup
[12.308s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[12.330s] [ext: omni.kit.menu.file-1.1.7] startup
[12.367s] [ext: omni.kit.property.layer-1.1.5] startup
[12.410s] [ext: omni.kit.multinode-0.1.1] startup
[12.424s] [ext: omni.kit.manipulator.transform-104.6.15] startup
[12.458s] [ext: omni.kit.property.audio-1.0.9] startup
[12.510s] [ext: omni.kit.property.camera-1.0.5] startup
[12.524s] [ext: omni.kit.property.geometry-1.2.11] startup
[12.570s] [ext: omni.hydra.scene_api-0.1.2] startup
[12.607s] [ext: omni.kit.property.light-1.0.8] startup
[12.634s] [ext: omni.kit.property.render-1.1.1] startup
[12.682s] [ext: omni.kit.property.transform-1.3.10] startup
[12.718s] [ext: omni.kit.property.skel-1.0.4] startup
[12.767s] [ext: omni.kit.property.material-1.8.36] startup
[12.814s] [ext: omni.kit.raycast.query-1.0.0] startup
[12.857s] [ext: omni.kit.widget.toolbar-1.5.6] startup
[12.964s] [ext: omni.kit.property.bundle-1.2.9] startup
[13.001s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[13.025s] [ext: omni.kit.manipulator.tool.snap-1.4.2] startup
[13.101s] [ext: omni.kit.widget.spinner-1.0.6] startup
[13.172s] [ext: omni.kit.manipulator.viewport-104.0.9] startup
[13.203s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[13.256s] [ext: omni.kit.viewport.menubar.core-105.0.19] startup
[13.470s] [ext: omni.kit.manipulator.prim-105.0.11] startup
[13.532s] [ext: omni.kit.manipulator.selection-104.0.8] startup
[13.550s] [ext: omni.kit.viewport.menubar.camera-105.1.9] startup
[13.639s] [ext: omni.kit.viewport.actions-105.1.6] startup
[13.705s] [ext: omni.kit.viewport.menubar.render-105.1.0] startup
[13.738s] [ext: omni.hydra.pxr.settings-1.0.5] startup
[13.776s] [ext: omni.kit.viewport.menubar.settings-105.0.9] startup
[13.852s] [ext: omni.kit.viewport.menubar.display-105.0.6] startup
[13.897s] [ext: omni.kit.widget.live-2.1.6] startup
[13.937s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[13.946s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[13.951s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
[14.505s] [ext: omni.kit.collaboration.viewport.camera-2.0.17] startup
[14.532s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[14.533s] [ext: omni.command.usd-1.0.2] startup
[14.546s] [ext: omni.kit.selection-0.1.3] startup
[14.564s] [ext: omni.kit.window.about-1.2.4] startup
[14.584s] [ext: omni.kit.window.console-0.2.10] startup
2023-12-13 10:03:35 [14,443ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Console *********************
2023-12-13 10:03:35 [14,443ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Console” from omni.kit.window.console.scripts.console_extension uses onclick_fn
[14.598s] [ext: omni.kit.window.privacy-0.1.0] startup
[14.612s] [ext: omni.kit.menu.edit-1.1.14] startup
[14.630s] [ext: omni.kit.window.script_editor-1.7.4] startup
[14.650s] [ext: omni.kit.widget.stage_icons-1.0.4] startup
[14.653s] [ext: omni.kit.window.status_bar-0.1.6] startup
[14.668s] [ext: omni.kit.window.tests-0.3.2] startup
[14.673s] [ext: omni.kit.window.title-1.1.3] startup
[14.678s] [ext: omni.kit.window.toolbar-1.5.4] startup
[14.687s] [ext: omni.rtx.settings.core-0.5.12] startup
[14.732s] [ext: omni.kit.window.stage-2.4.4] startup
2023-12-13 10:03:35 [14,590ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Stage *********************
2023-12-13 10:03:35 [14,590ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Stage” from omni.kit.window.stage.stage_extension uses onclick_fn
[14.743s] [ext: omni.kit.menu.common-1.1.4] startup
[14.749s] [ext: omni.kit.menu.aov-1.1.3] startup
[14.755s] [ext: omni.kit.collaboration.stage_columns-1.0.4] startup
[14.765s] [ext: omni.kit.window.stats-0.1.4] startup
[14.771s] [ext: omni.app.dev-1.0.0] startup
[14.778s] [ext: omni.avatar.livelink-105.11.1] startup
[16.072s] [ext: omni.kit.browser.core-2.3.10] startup
[16.119s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[16.342s] [ext: omni.audio2face.inference_deps-105.1.1] startup
[16.362s] [ext: omni.audio2face.emotion_deps-105.0.3] startup
[16.377s] [ext: omni.audio2face.inference-105.1.2] startup
[16.432s] [ext: omni.kit.graph.delegate.modern-1.9.2] startup
[16.471s] [ext: omni.kit.graph.delegate.default-1.1.2] startup
[16.490s] [ext: omni.audio2face.emotion-105.0.6] startup
[16.853s] [ext: omni.audio2face.core_deps-105.5.1] startup
[16.857s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[16.889s] [ext: omni.audio2face.ui.common-105.2.1] startup
[16.974s] [ext: omni.audio2face.player-105.1.1] startup
[17.352s] [ext: omni.audio2face.core-105.5.1] startup
[17.571s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[17.589s] [ext: omni.kit.graph.usd.commands-1.3.0] startup
[17.612s] [ext: omni.audio2face.ui.player-105.1.1] startup
[17.651s] [ext: omni.audio2face.ui.core-105.1.1] startup
[17.685s] [ext: omni.graph.window.core-1.84.0] startup
[17.780s] [ext: omni.audio2face.tool-105.4.1] startup
[17.838s] [ext: omni.graph.window.action-1.11.2] startup
2023-12-13 10:03:38 [17,697ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Action Graph *********************
2023-12-13 10:03:38 [17,698ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Action Graph” from functools uses onclick_fn
[17.850s] [ext: omni.audio2face.exporter-105.20.4] startup
[17.955s] [ext: omni.kit.browser.folder.core-1.9.9] startup
[17.978s] [ext: omni.anim.toolbox-105.7.0] startup
[18.038s] [ext: omni.kit.browser.sample-1.4.6] startup
2023-12-13 10:03:38 [17,905ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Examples *********************
2023-12-13 10:03:38 [17,905ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Examples” from omni.kit.browser.sample.extension uses onclick_fn
[18.056s] [ext: omni.warp.core-1.0.0-beta.4] startup
Warp 1.0.0-beta.4 initialized:
CUDA Toolkit: 11.5, Driver: 12.3
Devices:
“cpu” | Intel64 Family 6 Model 158 Stepping 10, GenuineIntel
“cuda:0” | NVIDIA GeForce RTX 3090 (sm_86)
Kernel cache: C:\Users\USER\AppData\Local\NVIDIA Corporation\warp\Cache\1.0.0-beta.4
[18.449s] [ext: omni.deform.deltaMush-105.5.4] startup
[18.561s] [ext: omni.deform.deltaBlend-105.5.3] startup
[18.624s] [ext: omni.kit.mesh_separate-105.2.1] startup
[18.642s] [ext: omni.kit.viewportDraw-105.2.1] startup
[18.730s] [ext: omni.warp-1.0.0-beta.4] startup
[18.956s] [ext: omni.kit.mesh.raycast-105.3.1] startup
[18.964s] [ext: omni.deform.prox-105.6.5] startup
[18.983s] [ext: omni.kit.ngsearch-0.3.3] startup
[18.989s] [ext: omni.graph.window.generic-1.9.3] startup
2023-12-13 10:03:39 [18,875ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Push Graph *********************
2023-12-13 10:03:39 [18,875ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Push Graph” from functools uses onclick_fn
2023-12-13 10:03:39 [18,876ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Lazy Graph *********************
2023-12-13 10:03:39 [18,876ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Lazy Graph” from functools uses onclick_fn
[19.041s] [ext: omni.kit.charTransfer-105.16.1] startup
[19.119s] [ext: omni.audio2face.wizard-105.9.0] startup
[19.133s] [ext: omni.kit.search.service-0.1.12] startup
2023-12-13 10:03:39 [19,066ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘SearchField’ object has no attribute ‘_container’
At:
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.widget.search_delegate/omni/kit/widget/search_delegate/widget.py(117): enabled
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.widget.search_delegate/omni/kit/widget/search_delegate/widget.py(368): _on_search_engines_changed
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.search_core/omni/kit/search_core/search_engine_registry.py(30): call
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.search_core/omni/kit/search_core/search_engine_registry.py(71): init
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.search_core/omni/kit/search_core/search_engine_registry.py(95): register_search_model
c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/extscache/omni.kit.search.service-0.1.12/omni/kit/search/service/scripts/extension.py(18): on_startup
c:\users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/kernel/py\omni\ext_impl_internal.py(166): startup_ext
.py(85): wrapper
2023-12-13 10:03:39 [19,067ms] [Error] [omni.kit.app._impl] [py stderr]: Exception ignored in:
Exception ignored in: 2023-12-13 10:03:39 [19,068ms] [Error] [omni.kit.app._impl] [py stderr]: <function SearchEngineRegistry._EngineSubscription.del at 0x00000121B725A830>
<function SearchEngineRegistry._EngineSubscription.del at 0x00000121B725A830>2023-12-13 10:03:39 [19,068ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-12-13 10:03:39 [19,068ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2023-12-13 10:03:39 [19,068ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.search_core/omni/kit/search_core/search_engine_registry.py”, line 76, in del
2023-12-13 10:03:39 [19,069ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-12-13 10:03:39 [19,069ms] [Error] [omni.kit.app._impl] [py stderr]: SearchEngineRegistry()._on_engines_changed()
SearchEngineRegistry()._on_engines_changed()2023-12-13 10:03:39 [19,069ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-12-13 10:03:39 [19,070ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.search_core/omni/kit/search_core/search_engine_registry.py”, line 30, in call
2023-12-13 10:03:39 [19,070ms] [Error] [omni.kit.app._impl] [py stderr]: f(*args, **kwargs)
f(*args, **kwargs)2023-12-13 10:03:39 [19,070ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-12-13 10:03:39 [19,071ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.widget.search_delegate/omni/kit/widget/search_delegate/widget.py”, line 368, in _on_search_engines_changed
2023-12-13 10:03:39 [19,071ms] [Error] [omni.kit.app._impl] [py stderr]: self.enabled = bool(search_names)
self.enabled = bool(search_names)2023-12-13 10:03:39 [19,071ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-12-13 10:03:39 [19,072ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/kit/exts/omni.kit.widget.search_delegate/omni/kit/widget/search_delegate/widget.py”, line 117, in enabled
2023-12-13 10:03:39 [19,072ms] [Error] [omni.kit.app._impl] [py stderr]: self._container.enabled = value
self._container.enabled = value2023-12-13 10:03:39 [19,072ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-12-13 10:03:39 [19,073ms] [Error] [omni.kit.app._impl] [py stderr]: AttributeError
AttributeError2023-12-13 10:03:39 [19,073ms] [Error] [omni.kit.app._impl] [py stderr]: :
: 2023-12-13 10:03:39 [19,073ms] [Error] [omni.kit.app._impl] [py stderr]: ‘SearchField’ object has no attribute ‘_container’
‘SearchField’ object has no attribute '_container’2023-12-13 10:03:39 [19,074ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-12-13 10:03:39 [19,074ms] [Error] [omni.ext.plugin] [ext: omni.kit.search.service-0.1.12] Failed to startup python extension.
[20.129s] [ext: omni.kit.freezeTransformations-105.2.1] startup
[20.157s] [ext: omni.kit.thumbnails.usd-1.0.4] startup
[20.373s] [ext: omni.kit.tool.asset_exporter-1.3.0] startup
[20.383s] [ext: omni.kit.tool.asset_importer-2.5.0] startup
[20.410s] [ext: omni.kit.window.modifier.titlebar-105.1.15] startup
[20.456s] [ext: omni.services.transport.server.base-1.1.1] startup
[20.487s] [ext: omni.kit.window.provide_feedback-1.0.2] startup
[20.506s] [ext: omni.kit.window.usd_paths-1.0.5] startup
[20.536s] [ext: omni.anim.curve-105.23.0] startup
[20.646s] [ext: omni.anim.retarget.core-105.1.8] startup
[20.678s] [ext: omni.services.transport.server.http-1.3.0] startup
[20.812s] [ext: omni.kit.profiler.window-2.2.0] startup
2023-12-13 10:03:41 [20,674ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.lt and use insort ‘key’ arg instead
[20.842s] [ext: omni.deform.ssd-105.2.1] startup
[20.899s] [ext: omni.anim.window.timeline-105.11.14] startup
[20.962s] [ext: omni.anim.skelJoint-105.1.17] startup
[20.979s] [ext: audio2face-2023.0.0] startup
2023-12-13 10:03:42 [21,537ms] [Warning] [omni.hydratexture.plugin] rtx::raytracing::RaycastQueryManager is not available
2023-12-13 10:03:42 [21,587ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2023-12-13 10:03:42 [21,587ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
2023-12-13 10:03:42 [21,625ms] [Warning] [omni.usd] Warning: in AppendProperty at line 858 of W:\ac88d7d902b57417\USD\pxr\usd\sdf\path.cpp – Can only append a property ‘node:type’ to a prim path (/)
2023-12-13 10:03:42 [21,628ms] [Warning] [omni.usd] Warning: in AppendProperty at line 858 of W:\ac88d7d902b57417\USD\pxr\usd\sdf\path.cpp – Can only append a property ‘node:type’ to a prim path (/)
2023-12-13 10:03:42 [21,644ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name=‘Task-22’ coro=<TimelineToolbar.__viewport_ready() done, defined at c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/extscache/omni.anim.window.timeline-105.11.14+105.1.ub3f/omni/anim/window/timeline/scripts/timeline_toolbar.py:106> exception=AttributeError(“‘NoneType’ object has no attribute ‘width’”)>
File “c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/extscache/omni.anim.window.timeline-105.11.14+105.1.ub3f/omni/anim/window/timeline/scripts/timeline_toolbar.py”, line 117, in __viewport_ready
self._show(self.MENU_PATH, show)
File “c:/users/USER/appdata/local/ov/pkg/audio2face-2023.2.0/extscache/omni.anim.window.timeline-105.11.14+105.1.ub3f/omni/anim/window/timeline/scripts/timeline_toolbar.py”, line 132, in _show
self._last_width = self._docked_window.width
AttributeError: ‘NoneType’ object has no attribute ‘width’
[21.793s] app ready
2023-12-13 10:03:44 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-12-13 10:03:44 [48ms] [Warn] [carb.crashreporter-breakpad.plugin] Launched process ‘py-spy.exe’ as PID 42232
2023-12-13 10:03:44 [252ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into ‘C:/Users/USER/AppData/Local/ov/data/Kit/Audio2Face/2023.2\64f1ec53-e7e9-4f57-ad80-f8619598c19d.dmp.zip’ for upload.
2023-12-13 10:03:45 [1,372ms] [Warn] [carb.crashreporter-breakpad.plugin] Launched process ‘crashreport.gui.exe’ as PID 39712
2023-12-13 10:04:15 [31,388ms] [Warn] [carb.crashreporter-breakpad.plugin] … waiting for PID 39712 to exit …
2023-12-13 10:04:45 [61,393ms] [Warn] [carb.crashreporter-breakpad.plugin] … waiting for PID 39712 to exit …
In particular, here are the ERRORS compiled:
  1. Aftermath D3D12 Failed to Initialize:
  • 2023-12-13 10:03:25 [4,500ms] [Warning] [carb.graphics-direct3d.plugin] Aftermath D3D12 failed to initialize.
  1. SetNvShaderExtnSlotSpace Failed:
  • 2023-12-13 10:03:25 [5,161ms] [Error] [carb.graphics-direct3d.plugin] SetNvShaderExtnSlotSpace() failed for slot: 9999, space: 0. status: -1
  1. CreateHeap Failed and Texture Creation Failed:
  • 2023-12-13 10:03:26 [5,589ms] [Error] [carb.graphics-direct3d.plugin] HRESULT: 0xffffffff
  • 2023-12-13 10:03:26 [5,590ms] [Error] [carb.graphics-direct3d.plugin] CreateHeap failed.
  • 2023-12-13 10:03:26 [5,591ms] [Error] [gpu.foundation.plugin] Texture creation failed for the device: 0.
  1. ResourceManager Initialization Failed:
  • 2023-12-13 10:03:26 [5,592ms] [Error] [gpu.foundation.plugin] rtx::resourcemanager::Context::init error: Creating placeholder textures failed.
  • 2023-12-13 10:03:26 [5,593ms] [Error] [gpu.foundation.plugin] Failed to initialize ResourceManager.
  1. GPU Foundation Devices Failed to Create:
  • 2023-12-13 10:03:26 [5,602ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices!
  1. TypeError in Python Script:
  • 2023-12-13 10:03:28 [7,712ms] [Error] [omni.ui.python] TypeError: unsupported operand type(s) for +: 'NoneType' and 'int'
  1. GPU Foundation Not Initialized:
  • 2023-12-13 10:03:28 [7,694ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
  • 2023-12-13 10:03:28 [7,698ms] [Error] [omni.kit.imgui_renderer.plugin] _prepareDefaultWindow: invalid device attached to the default window!
  1. AttributeError in Python Script:
  • 2023-12-13 10:03:39 [19,066ms] [Error] [carb.scripting-python.plugin] AttributeError: 'SearchField' object has no attribute '_container'
  1. Crash at Application End:
  • 2023-12-13 10:03:44 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.
When the application crashes, I also get a popup saying “The code execution cannot proceed because carb.dll was not found. Reinstalling the program may fix this problem” I have tried reinstalling, but unfortunately, I still get the same error. Any advice would be greatly appreciated!
Welcome to the forum @poruz.stanford
Can you do me a favour and try installing driver version 535 instead?
That worked! Driver 535 is not compatible with the RTX 3090, but I found an earlier RTX 3090 driver that was compatible (537.58). Thank you very much!
