Originally published at: https://developer.nvidia.com/blog/achieving-fp32-accuracy-for-int8-inference-using-quantization-aware-training-with-tensorrt/
○ TensorRT is an SDK for high-performance deep learning inference and with TensorRT 8.0, you can import models trained using Quantization Aware Training (QAT) to run inference in INT8 precision without losing FP32 accuracy. QAT significantly reduces compute required and storage overhead for efficient inference.
Hi, I’ve run the tutorial for resnet50 quantization from https://developer.nvidia.com/blog/achieving-fp32-accuracy-for-int8-inference-using-quantization-aware-training-with-tensorrt/
Then I’ve tested the runtime for quantized and unquantized onnx - and received similar runtime results on 3080 RTX.
What is the explanation for this?
