Cannot create the calibration cache for the QAT model in tensorRT 8
I’ve trained a quantized model (with help of quantized-aware-training method in pytorch). I want to create the calibration cache to do inference in INT8 mode by TensorRT. When create calib cache, I get the following warning and the cache is not created:
[03/06/2022-08:14:07] [TRT] [W] Calibrator won't be used in explicit precision mode. Use quantization aware training to generate network with Quantize/Dequantize nodes.
[03/06/2022-08:14:11] [TRT] [W] Some weights are outside of int8_t range and will be clipped to int8_t range.
I’ve trained the model accordingly and converted to ONNX:
import os
import sys
import argparse
import warnings
import collections
import torch
import torch.utils.data
from torch import nn
from tqdm import tqdm
import torchvision
from torchvision import transforms
from torch.hub import load_state_dict_from_url
from pytorch_quantization import nn as quant_nn
from pytorch_quantization import calib
from pytorch_quantization.tensor_quant import QuantDescriptor
from pytorch_quantization import quant_modules
import onnxruntime
import numpy as np
import models
import kornia
from prettytable import PrettyTable
from PIL import Image, ImageFile
ImageFile.LOAD_TRUNCATED_IMAGES = True
def get_parser():
    Creates an argument parser.
    parser = argparse.ArgumentParser(description='Classification quantization flow script')
    parser.add_argument('--data-dir', '-d', type=str, help='input data folder', required=True)
    parser.add_argument('--model-name', '-m', default='', help='model name: default resnet50')
    parser.add_argument('--disable-pcq', '-dpcq', action="store_true", help='disable per-channel quantization for weights')
    parser.add_argument('--out-dir', '-o', default='/tmp', help='output folder: default /tmp')
    parser.add_argument('--print-freq', '-pf', type=int, default=20, help='evaluation print frequency: default 20')
    parser.add_argument('--threshold', '-t', type=float, default=-1.0, help='top1 accuracy threshold (less than 0.0 means no comparison): default -1.0')
    parser.add_argument('--batch-size-train', type=int, default=8, help='batch size for training: default 128')
    parser.add_argument('--batch-size-test', type=int, default=8, help='batch size for testing: default 128')
    parser.add_argument('--batch-size-onnx', type=int, default=20, help='batch size for onnx: default 1')
    parser.add_argument('--seed', type=int, default=12345, help='random seed: default 12345')
    checkpoint = parser.add_mutually_exclusive_group(required=True)
    checkpoint.add_argument('--ckpt-path', default='', type=str, required=False,
                            help='path to latest checkpoint (default: none)')
    checkpoint.add_argument('--ckpt-url', default='', type=str, required=False,
                            help='url to latest checkpoint (default: none)')
    checkpoint.add_argument('--pretrained', action="store_true")
    parser.add_argument('--num-calib-batch', default=8, type=int,
                        help='Number of batches for calibration. 0 will disable calibration. (default: 4)')
    parser.add_argument('--num-finetune-epochs', default=0, type=int,
                        help='Number of epochs to fine tune. 0 will disable fine tune. (default: 0)')
    parser.add_argument('--calibrator', type=str, choices=["max", "histogram"], default="max")
    parser.add_argument('--percentile', nargs='+', type=float, default=[99.9, 99.99, 99.999, 99.9999])
    parser.add_argument('--sensitivity', action="store_true", help="Build sensitivity profile")
    parser.add_argument('--evaluate-onnx', action="store_true", help="Evaluate exported ONNX")
    return parser
def prepare_model(
        model_name,
        num_class,
        data_dir,
        per_channel_quantization,
        batch_size_train,
        batch_size_test,
        batch_size_onnx,
        calibrator,
        pretrained,
        ckpt_path,
        ckpt_url=None):
    ## Initialize quantization, model and data loaders
    if per_channel_quantization:
        print('<<<<<<< Per channel qaunt >>>>>>>>')
        quant_desc_input = QuantDescriptor(calib_method=calibrator)
        quant_nn.QuantConv2d.set_default_quant_desc_input(quant_desc_input)
        quant_nn.QuantLinear.set_default_quant_desc_input(quant_desc_input)
    else:
        ## Force per tensor quantization for onnx runtime
        print('<<<<<<< Per tensor qaunt >>>>>>>>')
        quant_desc_input = QuantDescriptor(calib_method=calibrator, axis=None)
        quant_nn.QuantConvTranspose2d.set_default_quant_desc_input(quant_desc_input)
        quant_desc_weight = QuantDescriptor(calib_method=calibrator, axis=None)
        quant_nn.QuantConv2d.set_default_quant_desc_weight(quant_desc_weight)
        quant_nn.QuantConvTranspose2d.set_default_quant_desc_weight(quant_desc_weight)
        quant_nn.QuantLinear.set_default_quant_desc_weight(quant_desc_weight)
    if model_name in models.__dict__:
        model = models.__dict__[model_name](pretrained=pretrained, quantize=True)
        num_feats = model.fc.in_features
        model.fc = nn.Linear(num_feats, num_class)
    else:
        print('Model is not available....downloading....')
        quant_modules.initialize()
        model = torchvision.models.__dict__[model_name](pretrained=pretrained)
        if 'resnet' in model_name:
        if 'densenet' in model_name:
            num_feats =  model.classifier.in_features
            model.classifier = nn.Linear(num_feats, num_class)
        quant_modules.deactivate()
    if not pretrained:
        if ckpt_path:
            model = torch.load(ckpt_path)
        else:
            model = load_state_dict_from_url(ckpt_url)
        if 'state_dict' in model.keys():
            model = model['state_dict']
        elif 'model' in model.keys():
            model = model['model']
        # model.load_state_dict(checkpoint)
    model.eval()
    model.cuda()
    print(model)
    ## Prepare the data loaders
    traindir = os.path.join(data_dir, 'train')
    valdir = os.path.join(data_dir, 'test')
    _args = collections.namedtuple("mock_args", ["model", "distributed", "cache_dataset"])
    dataset, dataset_test, train_sampler, test_sampler = load_data(
        traindir, valdir, _args(model=model_name, distributed=False, cache_dataset=False))
    data_loader_train = torch.utils.data.DataLoader(
        dataset, batch_size=batch_size_train,
        sampler=train_sampler, num_workers=4, pin_memory=True)
    data_loader_test = torch.utils.data.DataLoader(
        dataset_test, batch_size=batch_size_test,
        sampler=test_sampler, num_workers=4, pin_memory=True)
    data_loader_onnx = torch.utils.data.DataLoader(
        dataset_test, batch_size=batch_size_onnx,
    return model, data_loader_train, data_loader_test, data_loader_onnx
def main(cmdline_args):
    parser = get_parser()
    args = parser.parse_args(cmdline_args)
    print(parser.description)
    print(args)
    torch.manual_seed(args.seed)
    np.random.seed(args.seed)
    args.model_name = 'resnet34'
    args.data_dir = '/home/Dataset/'
    args.disable_pcq = True #set true to disbale
    args.batch_size_train = 8
    args.batch_size_test = 8
    args.batch_size_onnx = 8
    args.calibrator = 'max'
    args.pretrained = True
    args.ckpt_path = ''
    args.ckpt_url = ''
    args.num_class = 5
    ## Prepare the pretrained model and data loaders
    model, data_loader_train, data_loader_test, data_loader_onnx = prepare_model(
        args.model_name,
        args.num_class,
        args.data_dir,
        not args.disable_pcq,
        args.batch_size_train,
        args.batch_size_test,
        args.batch_size_onnx,
        args.calibrator,
        args.pretrained,
        args.ckpt_path,
        args.ckpt_url)
    kwargs = {"alpha": 0.75, "gamma": 2.0, "reduction": 'mean'}
    criterion = kornia.losses.FocalLoss(**kwargs)
    ## Calibrate the model
    with torch.no_grad():
        calibrate_model(
            model=model,
            model_name=args.model_name,
            data_loader=data_loader_train,
            num_calib_batch=args.num_calib_batch,
            calibrator=args.calibrator,
            hist_percentile=args.percentile,
            out_dir=args.out_dir)
    ## Build sensitivy profile
    if args.sensitivity:
        build_sensitivity_profile(model, criterion, data_loader_test)
    kwargs = {"alpha": 0.75, "gamma": 3.0, "reduction": 'mean'}
    optimizer = torch.optim.SGD(model.parameters(), lr=0.0001)
    lr_scheduler = torch.optim.lr_scheduler.CosineAnnealingLR(optimizer, args.num_finetune_epochs)
    for epoch in range(args.num_finetune_epochs):
        # Training a single epch
        train_one_epoch(model, criterion, optimizer, data_loader_train, "cuda", epoch, 100)
        lr_scheduler.step()
    if args.num_finetune_epochs > 0:
        ## Evaluate after finetuning
            print('Finetune evaluation:')
            top1_finetuned = evaluate(model, criterion, data_loader_test, device="cuda")
    else:
        top1_finetuned = -1.0
    ## Export to ONNX
    onnx_filename = args.out_dir + '/' + args.model_name + ".onnx"
    top1_onnx = -1.0
    if export_onnx(model, onnx_filename, args.batch_size_onnx, not args.disable_pcq) and args.evaluate_onnx:
        ## Validate ONNX and evaluate
        top1_onnx = evaluate_onnx(onnx_filename, data_loader_onnx, criterion, args.print_freq)
    ## Print summary
    print("Accuracy summary:")
    table = PrettyTable(['Stage','Top1'])
    table.align['Stage'] = "l"
    table.add_row( [ 'Finetuned',   "{:.2f}".format(top1_finetuned) ] )
    table.add_row( [ 'ONNX',        "{:.2f}".format(top1_onnx) ] )
    print(table)
    ## Compare results
    if args.threshold >= 0.0:
        if args.evaluate_onnx and top1_onnx < 0.0:
            print("Failed to export/evaluate ONNX!")
            return 1
            if top1_finetuned >= (top1_onnx - args.threshold):
                print("Accuracy threshold was met!")
            else:
                print("Accuracy threshold was missed!")
                return 1
    return 0
def evaluate_onnx(onnx_filename, data_loader, criterion, print_freq):
    print("Loading ONNX file: ", onnx_filename)
    ort_session = onnxruntime.InferenceSession(onnx_filename)
        metric_logger = utils.MetricLogger(delimiter="  ")
        header = 'Test:'
            for image, target in metric_logger.log_every(data_loader, print_freq, header):
                image = image.to("cpu", non_blocking=True)
                image_data = np.array(image)
                input_data = image_data
                # run the data through onnx runtime instead of torch model
                input_name = ort_session.get_inputs()[0].name
                raw_result = ort_session.run([], {input_name: input_data})
                output = torch.tensor((raw_result[0]))
                loss = criterion(output, target)
                acc1, acc5 = utils.accuracy(output, target, topk=(1, 5))
                batch_size = image.shape[0]
                metric_logger.update(loss=loss.item())
                metric_logger.meters['acc1'].update(acc1.item(), n=batch_size)
                metric_logger.meters['acc5'].update(acc5.item(), n=batch_size)
        # gather the stats from all processes
        metric_logger.synchronize_between_processes()
        print('  ONNXRuntime: Acc@1 {top1.global_avg:.3f} Acc@5 {top5.global_avg:.3f}'
            .format(top1=metric_logger.acc1, top5=metric_logger.acc5))
        return metric_logger.acc1.global_avg
def export_onnx(model, onnx_filename, batch_onnx, per_channel_quantization):
    model.eval()
    quant_nn.TensorQuantizer.use_fb_fake_quant = True # We have to shift to pytorch's fake quant ops before exporting the model to ONNX
        opset_version = 13
    else:
        opset_version = 12
    # Export ONNX for multiple batch sizes
    print("Creating ONNX file: " + onnx_filename)
    dummy_input = torch.randn(batch_onnx, 3, 224, 224, device='cuda') #TODO: switch input dims by model
    input_names = ['input']
    if 'resnet' in onnx_filename:
        print('Changing last layer of resnet...')
        output_names = ['Linear[fc]']  ### ResNet34
    if 'densenet' in onnx_filename:
        print('Changing last layer of densenet...')
        output_names = ['Linear[classifier]'] #### DenseNet
    dynamic_axes = {'input': {0: 'batch_size'}}
    try:
        torch.onnx.export(model, dummy_input, onnx_filename, input_names=input_names,
                          export_params=True, output_names=output_names, opset_version=opset_version,
                          dynamic_axes=dynamic_axes, verbose=True, enable_onnx_checker=False, do_constant_folding=True)
    except ValueError:
        warnings.warn(UserWarning("Per-channel quantization is not yet supported in Pytorch/ONNX RT (requires ONNX opset 13)"))
        print("Failed to export to ONNX")
        return False
    return True
def calibrate_model(model, model_name, data_loader, num_calib_batch, calibrator, hist_percentile, out_dir):
    if num_calib_batch > 0:
        print("Calibrating model")
            collect_stats(model, data_loader, num_calib_batch)
        if not calibrator == "histogram":
            compute_amax(model, method="max")
            calib_output = os.path.join(
                out_dir,
                F"{model_name}-max-{num_calib_batch*data_loader.batch_size}.pth")
            # torch.save(model.state_dict(), calib_output) # Just weights
            torch.save(model, calib_output) # whole model
        else:
            for percentile in hist_percentile:
                print(F"{percentile} percentile calibration")
                compute_amax(model, method="percentile")
                    out_dir,
                    F"{model_name}-percentile-{percentile}-{num_calib_batch*data_loader.batch_size}.pth")
            for method in ["mse", "entropy"]:
                print(F"{method} calibration")
                compute_amax(model, method=method)
                    out_dir,
                    F"{model_name}-{method}-{num_calib_batch*data_loader.batch_size}.pth")
def collect_stats(model, data_loader, num_batches):
    # Enable calibrators
    for name, module in model.named_modules():
        if isinstance(module, quant_nn.TensorQuantizer):
            if module._calibrator is not None:
                module.disable_quant()
                module.enable_calib()
            else:
                module.disable()
    # Feed data to the network for collecting stats
    for i, (image, _) in tqdm(enumerate(data_loader), total=num_batches):
        model(image.cuda())
        if i >= num_batches:
            break
    # Disable calibrators
                module.enable_quant()
                module.disable_calib()
            else:
                module.enable()
def compute_amax(model, **kwargs):
    # Load calib result
                if isinstance(module._calibrator, calib.MaxCalibrator):
                    module.load_calib_amax()
                else:
                    module.load_calib_amax(**kwargs)
            print(F"{name:40}: {module}")
    model.cuda()
def build_sensitivity_profile(model, criterion, data_loader_test):
    quant_layer_names = []
        if name.endswith("_quantizer"):
            module.disable()
            layer_name = name.replace("._input_quantizer", "").replace("._weight_quantizer", "")
            if layer_name not in quant_layer_names:
                quant_layer_names.append(layer_name)
    for i, quant_layer in enumerate(quant_layer_names):
        print("Enable", quant_layer)
            if name.endswith("_quantizer") and quant_layer in name:
                module.enable()
                module.disable()
if __name__ == '__main__':
    res = main(sys.argv[1:])
    exit(res)
More info regarding the system:
TensorRT Version: 8.2.3
GPU Type: NVIDIA GeForce GTX 1050 Ti
Nvidia Driver Version: 470.103.01
CUDA Version: 11.6
CUDNN Version: N/A
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8
TensorFlow Version (if applicable): N/A
PyTorch Version (if applicable): 1.9.0+cu111
Baremetal or Container (if container which image + tag): nvcr.io/nvidia/tensorrt :22.02-py3 (with slightly changes)
Is there any problem with ONNX conversion or TensorRT version?
Hope following may help you.
If you still face this issue, could you please share with us ONNX model.
Thank you.
Thank you for your reply. I’ve checked the links. I’m using Pytorch as my framework. I employed the example of below link for quantized-aware-training:
classification_flow.py
As you asked my ONNX model, I juts trained the pretrained-model from pytorch model zoo, ResNet-34 which is available.
Finally, I found out the quantized models don’t need the calibration cache. TensorRT detects the Q/DQ layers and the qauntized model has its own scale and range.
