https://www.nvidia.com/content/dam/en-zz/Solutions/design-visualization/proviz-print-rtx6000-datasheet-web-2504660.pdf States that RTX6000 Ada has generation 2 RT cores, but 4090 has generation 3 RT cores. Is this correct?
All Ada architecture GPUs have the third generation of RT cores. Turing was the first, Ampere the second generation.
Yeah, looks like copy-paste errors in the table. The text has it right:
“Built on the NVIDIA Ada Lovelace architecture, the RTX 6000 (Ada Generation) combines 142 third-generation RT Cores, 568 fourth-generation Tensor Cores, and 18,176 CUDA® cores with 48GB of error correction code (ECC) graphics memory.”
Thanks for pointing it out. I’ll inform our marketing department.
