I have a Jetson Nano hooked up to the Servo Driver with power and I am attempting to run this code:
from __future__ import division
import time
import Adafruit_PCA9685
pwm = Adafruit_PCA9685.PCA9685()
But I am getting this error:
File "Motor Test.py", line 5, in <module>
File "/usr/local/lib/python3.6/dist-packages/Adafruit_PCA9685/PCA9685.py", line 74, in __init__
self._device = i2c.get_i2c_device(address, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/Adafruit_GPIO/I2C.py", line 63, in get_i2c_device
busnum = get_default_bus()
File "/usr/local/lib/python3.6/dist-packages/Adafruit_GPIO/I2C.py", line 55, in get_default_bus
raise RuntimeError('Could not determine default I2C bus for platform.')
RuntimeError: Could not determine default I2C bus for platform.
I ran this exact code and libraries on the raspberry pi and they worked with the exact same setup. I had to do sudo raspi-config for the raspberry to allow the use of I2C but I haven’t found an equivalent for the Jetson.
Please help :(
