**• Hardware Platform (Jetson / GPU)**GPU • DeepStream Version5.0 • JetPack Version (valid for Jetson only) • TensorRT Version7.1.3
**• NVIDIA GPU Driver Version (valid for GPU only)**10.2
Hi
I’m running face recognition. At the second model, i need to transpose copped image then feed it. I inserted gstdsexample between face detection model and face embedding model. however it seems incorrect. this is code to build pipeline
inter_buf is temporarily used inside dsexample which will never be transferred to downstream. It is not a proper way to do preprocessing outside nvinfer.
It is necessary to review and understand the whole codes for nvinfer first. The plugin codes are in /opt/nvidia/deepstream/deepstream-5.0/sources/gst-plugins/gst-nvinfer and /opt/nvidia/deepstream/deepstream-5.0/sources/libs/nvdsinfer. And then you can judge whether it is suitable to add this kind of pre-processing in it.
[quote=“Fiona.Chen, post:7, topic:153797”]
thanks for your suggest, i will come back if the issue was solved.
