• Hardware Platform (Jetson / GPU) Jetson AGX orin
• DeepStream Version 7
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version 8.6
**• Cuda 12.2
• Issue Type( questions, new requirements, bugs) questions
I have trained a UNET segmentation model with float32 images of two channels (RG).
I would like to use deepstream to run a pipeline and run inference.
I think I can use nvdspreprocess to put my data in the right format (float32 2 channels) but I am not sure. Do you have an example of nvdspreprocess usage ?
Also how can I use nvinfer after nvdspreprocess in that context, since nvinfer expects RGB or GRAY images and int8 only ? My model expect float32-two channels images so is there a way to configure nvinfer in such a way ?
