I am trying to edit a device tree to be able to use an eMMC device that is on a custom carrier board. I’ve learned about the device tree data structure and how it’s interpreted. I know how to use dtc tool to convert the existing .dtb file into a .dts file and convert this back into a .dtb file.
The issue I am having is that I don’t know exactly what to add to the .dts file in order for the linux device to recognize this module.
Here are some of my main questions regarding Device Trees:
I have been using commands ‘lsblk’ and ‘df’ to check the storage available. Will the eMMC device show up with these commands if the Device Tree is edited correctly?
If I make the successful edit to the device tree and I replace the existing .dtb file with the updated .dtb and reboot the machine, will this device be present when I run ‘lsblk’ command? Or are there more steps to make this device discoverable? So essentially I’m asking if during bootup, does the kernel just grab whatever .dtb file is at that location and use it as the blueprint? Is it that simple or is the .dtb file more ‘embedded’ into the kernel than that?
This is my first attempt at editing a device tree so there is a lot of holes in my knowledge that I am trying to figure out.
Thank you for the help.
