We know that cuda texture supports various address modes to handle out-of-range texture access, but according to CUDA Runtime API, this functionality is not available for texture binding to linear memory:
cudaTextureDesc::addressMode specifies the addressing mode for each dimension of the texture data. cudaTextureAddressMode is defined as:
enum cudaTextureAddressMode {
cudaAddressModeWrap = 0,
cudaAddressModeClamp = 1,
cudaAddressModeMirror = 2,
cudaAddressModeBorder = 3
This is ignored if cudaResourceDesc::resType is cudaResourceTypeLinear. Also, if cudaTextureDesc::normalizedCoords is set to zero, cudaAddressModeWrap and cudaAddressModeMirror won’t be supported and will be switched to cudaAddressModeClamp.
Read more at: http://docs.nvidia.com/cuda/cuda-runtime-api/index.html#ixzz3qIfktSOR
Follow us: @GPUComputing on Twitter | NVIDIA on Facebook
My question is: what happens if I access invalid elements in texture binding to linear memory?
a. everything goes smoothly just like textures binding to cudaArray;
b. the kernel returns successfully, but the fetched value is corrupted;
c. the kernel returns “corrupted memory access” error code and the program terminates;
d. undefined.
I didn’t find much detailed explanation in cuda manual, could anyone help me?
Thanks in advance.
