I’m currently trying to understand how the cudaAddressModeWrap for 2D textures works.
I wrote the following code to test things out:
#include <stdio.h>
#define gpuErrchk(ans) { gpuAssert((ans), __FILE__, __LINE__); }
inline void gpuAssert(cudaError_t code, const char *file, int line, bool abort=true)
if (code != cudaSuccess) {
fprintf(stderr,"GPUassert: %s %s %d\n", cudaGetErrorString(code), file, line);
if (abort) exit(code);
texture<float, 2, cudaReadModeElementType> texRef;
__global__
void testTexture(int col, int row) {
printf("%f\n", tex2D(texRef, col, row));
int main()
float data[5][4] =
{1,2,3,4},
{5,6,7,8},
{9,10,11,12},
{13,14,15,16},
{17,18,19,20}
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(32, 0, 0, 0, cudaChannelFormatKindFloat);
cudaArray *cuArray;
gpuErrchk(cudaMallocArray(&cuArray, &channelDesc, 4, 5));
gpuErrchk(cudaMemcpyToArray(cuArray, 0, 0, data, 5 * 4 * sizeof(float), cudaMemcpyHostToDevice));
// Set texture parameters
texRef.addressMode[0] = cudaAddressModeWrap;
texRef.addressMode[1] = cudaAddressModeWrap;
//texRef.filterMode = cudaFilterModeLinear;
//texRef.normalized = true; // access with normalized texture coordinates
// Bind the array to the texture
gpuErrchk(cudaBindTextureToArray(texRef, cuArray, channelDesc));
testTexture<<<1, 1>>>(4, 0);
gpuErrchk(cudaFreeArray(cuArray));
return EXIT_SUCCESS;
testTexture<<<1, 1>>>(0, 0) prints, as expected, “1.000000”.
testTexture<<<1, 1>>>(1, 0) prints, as expected, “2.000000”.
testTexture<<<1, 1>>>(2, 0) prints, as expected, “3.000000”.
testTexture<<<1, 1>>>(3, 0) prints, as expected, “4.000000”.
But:
testTexture<<<1, 1>>>(4, 0) prints “4.000000”.
Why? I would expect it to wrap around and print “1.000000” again. How does the wrap mode work?
Edit: I tried it now with a combination of cudaMallocPitch and cudaBindTexture2D. However, this gives me completely wrong values, even for indices inside the texture borders. What is wrong?
#include <stdio.h>
__global__
int main()
float data[5][4] =
{1,2,3,4},
{5,6,7,8},
{9,10,11,12},
{13,14,15,16},
{17,18,19,20}
size_t pitch;
size_t offset;
float * gpu_data;
gpuErrchk(cudaMallocPitch((void**) &gpu_data, &pitch, 4 * sizeof(float), 5));
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<float>();
gpuErrchk(cudaMemcpy2D(gpu_data, pitch, data, 4 * sizeof(float), 4, 5, cudaMemcpyHostToDevice));
gpuErrchk(cudaBindTexture2D(0, &texRef, gpu_data, &channelDesc, 4, 5, pitch));
testTexture<<<1, 1>>>(2, 0);
gpuErrchk(cudaFree(gpu_data));
