Adjust Gain/Exposure in opencv on Jetson Nano
I am using a Raspberry v2 Csi camera in opencv. As far as I know this is only working with gstreamer pipelines.
As my lighting situation is difficult sometimes I was wondering if i could set the auto exposure or gain properties manually. After sole tests I realized that cv2.set(cv2.propery) doesn‘t work with gstreamer.
Do you know how to do it?
I am using opencv 4.6.0
Hi @whos.boom,
Could you share the GStreamer pipeline you are using for capturing with OpenCV?
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
I found this in this forum and then added my pipeline:
import cv2
gstreamer_pipeline returns a GStreamer pipeline for capturing from the CSI camera
Flip the image by setting the flip_method (most common values: 0 and 2)
display_width and display_height determine the size of each camera pane in the window on the screen
Default 1920x1080 displayd in a 1/4 size window
def gstreamer_pipeline(
    sensor_id=0,
    capture_width=1640,
    capture_height=1232,
    display_width=640,
    display_height=480,
    framerate=30,
    flip_method=2,
    return (
        "nvarguscamerasrc sensor-id=%d !"
        "video/x-raw(memory:NVMM), width=(int)%d, height=(int)%d, framerate=(fraction)%d/1 ! "
        "nvvidconv flip-method=%d ! "
        "video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
        "videoconvert ! "
        "video/x-raw, format=(string)BGR ! appsink max-buffers=1 drop=True"
            sensor_id,
            capture_width,
            capture_height,
            framerate,
            flip_method,
            display_width,
            display_height,
# Open Pi Camera
cap = cv2.VideoCapture(gstreamer_pipeline(sensor_id=0), cv2.CAP_GSTREAMER)
# Set auto exposure to false
cap.set(cv2.CAP_PROP_AUTO_EXPOSURE, 0.75)
exposure = 0
while cap.isOpened():
    # Grab frame
    ret, frame = cap.read()
    # Display if there is a frame
    if ret:
        cv2.imshow('Frame', frame)
        if cv2.waitKey(25) & 0xFF == ord('q'):
            break
    # Set exposure manually
    cap.set(cv2.CAP_PROP_GAIN, exposure)
    # Increase exposure for every frame that is displayed
    exposure += 0.5
# Close everything
cap.release()
cv2.destroyAllWindows()
Note that ArgusCamera is not a real camera device, it is an application that manages a camera.
So by default it tries to auto-tune gains, exposure, whitebalance.
The real camera in case of RPi v2 Cam is a bayer RG10 device.
So if you turn off auto-tuning and set exposure to real device, it may work:
import cv2
import subprocess
import time
    sensor_id=0,
    capture_width=1280,
    capture_height=720,
    display_width=640,
    display_height=480,
    framerate=30,
    flip_method=2,
    return (
        "nvarguscamerasrc sensor-id=%d gainrange=\"16 16\" ispdigitalgainrange=\"1 1\"  aelock=1 awblock=1 ! "
        "videoconvert ! "
            sensor_id,
            capture_width,
            capture_height,
            framerate,
            flip_method,
            display_width,
            display_height,
min_exposure = 13
max_exposure = 29999
exposure_step = 500
exposure = min_exposure
# Open Pi Camera
    # Grab frame
    if ret:
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    start = time.time()
    subprocess.check_output(['v4l2-ctl', '--set-ctrl', 'exposure='+str(exposure)]).decode("utf-8")
    end = time.time()
    print('time to set exposure %f seconds' %(end - start))
    print(subprocess.check_output(['v4l2-ctl', '--get-ctrl', 'exposure']).decode("utf-8"))
    print(subprocess.check_output(['v4l2-ctl', '--get-ctrl', 'gain']).decode("utf-8"))
    exposure += exposure_step
    if exposure > max_exposure :
# Close everything
cap.release()
However, you’ll see that it takes more than one frame (~ 40 ms on Xavier-NX without boosting clocks), so it may not be suitable for changing exposure on each frame.
It may be possible to do that using v4l2 interface from python. I remember this post:
You may also try to see what is under the hood with strace:
sudo apt install strace
strace v4l2-ctl --set-ctrl exposure=55
ioctl(3, VIDIOC_S_EXT_CTRLS, {ctrl_class=V4L2_CTRL_CLASS_CAMERA, count=1, controls=[{id=0x9a200a /* V4L2_CID_??? */, size=0, value=55, value64=55}] => controls=[{id=0x9a200a /* V4L2_CID_??? */, size=0, value=55, value64=55}]}) = 0
Someone better skilled may further help.
I‘ve tried your code and it worked how you described. The delay I get makes it not usable for me as I am using two cameras. I am working now with the gain range fron the pipeline and I get better results from my detection although the lightning is not perfekt in every situation. To be able to control things a little bit more I have installed a led that I can control in brightness. Its not making the view much brighter but its influencing the auto exposure of my camera.
As this is just a workaround I am still interested in learning how to do that directly. Hope someone can help!
Note that nvarguscamerasrc also has an exposuretimerange property if it helps:
gst-inspect-1.0 nvarguscamerasrc
If not enough, the low performance from the code I posted above may be because of subprocess creation and launch. It may be much faster if you can issue V4L ioctls, but I am unable to further help for this case, I have very poor experience of v4l from python.
