ADV7280M Special Effect
Hi @DaneLLL , @JerryChang , CC @ShaneCCC ,
While I haven’t found any problem in the driver (compare to the reference scripts from Analog Device for predefined modes), I found similar issue on TX2 in ADV7280-M capture problem which was resolved by the following patch : Video For Linux (V4L) issue for onboard OV5693
The mentioned patch seems to be applied in r32.5.1, I tried with –set-ctrl preferred_stride=256, 720 or 1440 but the output was the same.
@ShaneCCC also recommended to modify :#define RM_SURFACE_ALIGNMENT 256 in vi4_fops.c but it was for TX2. How could I proceed with Xavier NX, please ?
Best Regards,
K.
