Fail to preview from adv7280m since Jetpack-4.6.1 onward
Dear Experts,
I would like to re-open an old ticket of myself as it was automatically closed 14 days after the last reply and also I needed to wait for new BSP releases in expecting that the issue could be resolve but it has not been the case yet: Cannot capture from adv7280m with Jetpack-4.6.1
For shortening the story, I borrowed and adapted the driver of adv7280m from the following post : ADV7280m configuration - #105 by hoanganhv1svm
Then I successfully ported for Xavier NX with Jetpack-4.5.1 : ADV7280M Special Effect
Until today, I have been testing the driver with Jetpack-4.6.1, Jetpack-4.6.2, Jetpack-4.6.3 and even Jetpack-5.0.2 but the issue still persists on Jetson Xavier NX.
However, the driver works perfectly with the TX2 NX for any Jetpack-4.6.x with the following patch : ADV7280m configuration - #69 by ShaneCCC
I found that in another discussion, @ShaneCCC proposed similar patch for Xavier NX (Jetpack-4.6.x) : Adv7282 PAL to MIPI CSI Linux Driver Development - #80 by ShaneCCC which is IMX219 Raw8 mode on the XavierNX: Disabling CRC - #9 by ShaneCCC
I then applied the patch and re-flash the rtcpu firmware as instructed but not any luck.
Below is the log with the patch applied to csi5_fops.c and the newly flashed rtcpu firmware :
nvidia@Jetson-XNX:~/Workspace$ v4l2-ctl --all -d /dev/video1
Driver Info (not using libv4l2):
	Driver name   : tegra-video
	Card type     : vi-output, adv7280 8-0020
	Bus info      : platform:15c10000.vi:4
	Driver version: 4.9.255
	Capabilities  : 0x84200001
		Video Capture
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps   : 0x04200001
		Video Capture
		Streaming
		Extended Pix Format
Priority: 2
Video input : 0 (Camera 4: no power)
DV timings:
	Active width: 0
	Active height: 0
	Total width: 0
	Total height: 0
	Frame format: progressive
	Polarities: -vsync -hsync
	Pixelclock: 0 Hz
	Horizontal frontporch: 0
	Horizontal sync: 0
	Horizontal backporch: 0
	Vertical frontporch: 0
	Vertical sync: 0
	Vertical backporch: 0
	Standards:
	Flags:
Format Video Capture:
	Width/Height      : 720/507
	Pixel Format      : 'UYVY'
	Field             : None
	Bytes per Line    : 1536
	Size Image        : 778752
	Colorspace        : SMPTE 170M
	Transfer Function : Rec. 709
	YCbCr/HSV Encoding: ITU-R 601
	Quantization      : Limited Range
	Flags             :
User Controls
                     brightness 0x00980900 (int)    : min=-128 max=127 step=1 default=0 value=0 flags=slider
                       contrast 0x00980901 (int)    : min=0 max=255 step=1 default=128 value=128 flags=slider
                     saturation 0x00980902 (int)    : min=0 max=255 step=1 default=128 value=128 flags=slider
                            hue 0x00980903 (int)    : min=-127 max=128 step=1 default=0 value=0 flags=slider
                 fast_switching 0x00981970 (bool)   : default=0 value=0
Camera Controls
           sensor_configuration 0x009a2032 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
         sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
      sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
                    bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
                override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
                   height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                     size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
               write_isp_format 0x009a2068 (int)    : min=1 max=1 step=1 default=1 value=1
       sensor_signal_properties 0x009a2069 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
        sensor_image_properties 0x009a206a (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
      sensor_control_properties 0x009a206b (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
              sensor_dv_timings 0x009a206c (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
               low_latency_mode 0x009a206d (bool)   : default=0 value=0
               preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=1472
                   sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=30 flags=read-only
nvidia@Jetson-XNX:~/Workspace$ sudo ./max_clock.sh
[sudo] password for nvidia:
vi clock rate is:460800000
isp clock rate is:576000000
emc clock rate is:1866000000
nvcsi clock rate is:314000000
nvidia@Jetson-XNX:~/Workspace$ sudo ./trace_on.sh
Run "sudo cat /sys/kernel/debug/tracing/trace" to visualize trace
nvidia@Jetson-XNX:~/Workspace$ sudo cat /sys/kernel/debug/tracing/trace > adv7280m.trace
adv7280m.trace (1.4 MB)
In the log file :
     kworker/0:0-4     [000] ....   892.894599: rtcpu_vinotify_event: tstamp:28375149639 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:27531433856 data:0x01020003
     kworker/0:0-4     [000] ....   892.894600: rtcpu_vinotify_event: tstamp:28375149770 tag:FE channel:0x00 frame:2 vi_tstamp:28375060379 data:0x00000024
     kworker/0:0-4     [000] ....   892.894601: rtcpu_vinotify_event: tstamp:28375149919 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:28375060380 data:0x00000000
     kworker/0:0-4     [000] ....   892.894601: rtcpu_vinotify_event: tstamp:28375150046 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27533640384 data:0x07020004
     kworker/0:0-4     [000] ....   892.894602: rtcpu_vinotify_event: tstamp:28375150203 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:28375069511 data:0x00010000
     kworker/0:0-4     [000] ....   892.894603: rtcpu_vinotify_event: tstamp:28375150333 tag:FS channel:0x00 frame:1 vi_tstamp:28375107479 data:0x00000014
     kworker/0:0-4     [000] ....   892.894604: rtcpu_vinotify_event: tstamp:28375150482 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:28375107480 data:0x00000000
     kworker/0:0-4     [000] ....   892.894604: rtcpu_vinotify_event: tstamp:28375150609 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:28375107531 data:0x00000001
     kworker/0:0-4     [000] ....   892.894605: rtcpu_vinotify_event: tstamp:28375150758 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:27535147968 data:0x08020004
     kworker/0:0-4     [000] ....   892.894606: rtcpu_vinotify_event: tstamp:28375615989 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:28375614440 data:0x01fa0002
     kworker/0:0-4     [000] ....   892.894607: rtcpu_vinotify_error: tstamp:28375692476 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:28375691622 data:0x00010000
     kworker/0:0-4     [000] ....   892.894607: rtcpu_vinotify_error: tstamp:28375730469 tag:CHANSEL_NOMATCH channel:0x10 frame:2 vi_tstamp:28375729631 data:0x000003c9
     kworker/0:0-4     [000] ....   892.894608: rtcpu_vinotify_event: tstamp:28375928849 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:28375614455 data:0x00000000
     kworker/0:0-4     [000] ....   892.894609: rtcpu_vinotify_event: tstamp:28375928983 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:27551369824 data:0x02020004
     kworker/0:0-4     [000] ....   892.894609: rtcpu_vinotify_event: tstamp:28375929132 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:28375614616 data:0x01fb0040
With :
CHANSEL_FAULT data bit field
    bit 16:31  LINE_NUMBER
    bit 15	DTYPE_MISMATCH
    bit 14	EMBED_INFRINGE
    bit 13	EMBED_LONG_LINE
    bit 12	EMBED_SPURIOUS
    bit 11	EMBED_RUNAWAY
    bit 10	EMBED_MISSING_LE
    bit 9	PIXEL_SHORT_LINE
    bit 8	PIXEL_LONG_LINE
    bit 7	PIXEL_SPURIOUS
    bit 6	PIXEL_RUNAWAY
    bit 5	PIXEL_MISSING_LE
    bit 4	PIXEL_LINE_TIMER
    bit 3	EMBED_EOF
    bit 2	EMBED_SOF
    bit 1	PIXEL_EOF
    bit 0	PIXEL_SOF
The trace shows the 0x01fb0040, with 0x40 means CHANSEL_FAULT of PIXEL_RUNAWAY.
I am really stuck and hope that you could help to point out what did happen btw the Jetpack-4.5.x and the later ones, please?
Best Regards,
Khang
Additional information : the resolution 720x507 come from the following discussion : Solved: iMX7D : NTSC Video Capture - NXP Community
I would suggest move the r35.1 for this module.
Hi @ShaneCCC ,
I did :
But I will provide the log/trace again for that version.
Hi @ShaneCCC.
I re-did the test with the rce firmware mentioned here : Camera failed with log:VIFALC_TDSTATE on Jetpack5.0.2 - #4 by JerryChang :
[  163.622618] adv7280: adv7180_s_stream( enable=1 )
[  163.646224] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 131072
[  163.673106] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 204000000 Hz.
[  163.673129] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=4, csi=4)
[  163.673142] [RCE] MIPI clock = 102000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[  163.673151] [RCE] ===== NVCSI Stream Configuration =====
[  163.673160] [RCE] stream_id: PP 4, csi_port: PORT E
[  163.673169] [RCE] Brick: PHY 2, Mode: D-PHY
[  163.673178] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 1
[  163.673187] [RCE] Clock information:
[  163.673196] [RCE] MIPI clock rate: 102.00 MHz
[  163.673204] [RCE] T_HS settle: 0, T_CLK settle: 0
[  163.673213] [RCE] ======================================
[  163.673222] [RCE] tegra_nvcsi_stream_open(vm0, stream=4, csi=4)
[  163.673231] [RCE] nvcsi_calc_ths_settle ths_settle 25
[  163.673240] [RCE] nvcsi_calc_ths_settle ths_settle 25
[  163.673249] [RCE] nvcsi_calc_tclk_settle tclk_settle 33
[  163.678901] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 131072
[  163.692651] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 131072
[  163.709547] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 131072
Full dmesg and trace are attached.
dmesg.txt (94.8 KB)
adv7280m.trace2 (1.9 MB)
In the following video, I was able to capture from the beginning and nearly the end of the vokoscreen video but this rarely happened, and then failed multiple of times (same as Jetpak-4.6.x) : jp502-adv7280m-unstable.mkv - Google Drive
Regards,
K.
Did you try to adjust the output size in sensor driver to verify CHANSEL_SHORT_FRAME message?
Hi @ShaneCCC,
From the document of ADV7280x, output formats are either 720x507 for NTSC and 720x576 for PAL:
I am testing with NTSC. So I have not had idea of what could be other values of height.
Btw, should I modify physical_w and physical_h in below device-tree node ?
            adv7280_e@20 {
                    compatible = "adi,adv7280-m";
                    /* I2C device address */
                    reg = <0x20>;
                    /* V4L2 device node location */
                    devnode = "video1";
                    /* Physical dimensions of sensor */
                    physical_w = "4.713";
                    physical_h = "3.494";
                    sensor_model = "adv7280-m";
                    use_sensor_mode_id = "false";
                    reset-gpios = <&mcp23008_27 2 GPIO_ACTIVE_LOW>;
                    ports {
                            #address-cells = <1>;
                            #size-cells = <0>;
                            port@0 {
                                    reg = <0>;
                                    adv7280_out0: endpoint {
                                            port-index = <4>; /* CSI E */
                                            bus-width = <1>;
                                            remote-endpoint = <&adv7280_csi_in0>;
Or should I add active_w and active_h as in following post : MIPI Streaming error issue - #3 by JerryChang ?
You can check by v4l2-ctl --list-formats-ext to confirm if modify the device tree otherwise need to modify from sensor driver.
Hi @ShaneCCC ,
There’s no such info from the driver in my system :
nvidia@Jetson-XNX:~$ v4l2-ctl --list-formats-ext -d /dev/video1
ioctl: VIDIOC_ENUM_FMT
	Type: Video Capture
	[0]: 'UYVY' (UYVY 4:2:2)
Could it be a problem in recent BSPs?
While :
nvidia@Jetson-XNX:~$ v4l2-ctl --all -d /dev/video1
Driver Info:
	Bus info         : platform:tegra-capture-vi:4
	Driver version   : 5.10.104
		Video Capture
		Streaming
		Extended Pix Format
		Device Capabilities
		Video Capture
		Streaming
		Extended Pix Format
Media Driver Info:
	Driver name      : tegra-camrtc-ca
	Model            : NVIDIA Tegra Video Input Device
	Serial           :
	Bus info         :
	Media version    : 5.10.104
	Hardware revision: 0x00000003 (3)
Interface Info:
	Type             : V4L Video
Entity Info:
	Name             : vi-output, adv7280 8-0020
	Function         : V4L2 I/O
	Pad 0x0100001a   : 0: Sink
	  Link 0x0200001f: from remote pad 0x1000006 of entity '13e10000.host1x:nvcsi@15a00000-': Data, Enabled
Priority: 2
Video input : 0 (Camera 4: ok)
DV timings:
	Active width: 0
	Active height: 0
	Total width: 0
	Total height: 0
	Pixelclock: 0 Hz
	Horizontal sync: 0
	Vertical sync: 0
	Standards:
	Flags:
	Pixel Format      : 'UYVY' (UYVY 4:2:2)
	Field             : None
	Bytes per Line    : 1472
	Size Image        : 746304
	Flags             :
User Controls
Camera Controls
           sensor_configuration 0x009a2032 (u32)    : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
         sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
      sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
				0: 0 (0x0)
				1: 1 (0x1)
				0: 0 (0x0)
				1: 1 (0x1)
				0: 1 (0x1)
				1: 65536 (0x10000)
				2: 131072 (0x20000)
       sensor_signal_properties 0x009a2069 (u32)    : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
        sensor_image_properties 0x009a206a (u32)    : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
      sensor_control_properties 0x009a206b (u32)    : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
              sensor_dv_timings 0x009a206c (u32)    : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
Not sure if below info is relevant, but I got this during the repetition of gst-launch :
[ 1447.476903] adv7280 8-0020: Autodetection result: 00
[ 1447.477394] adv7280 8-0020: Interlaced video detected (status3=0x69)
[ 1453.074181] CPU:0, Error:rce-noc@0xbe00000,irq=21
[ 1453.074346] **************************************
[ 1453.074459] CPU:0, Error:rce-noc
[ 1453.074575]  Error Logger            : 0
[ 1453.074690]  ErrLog0                 : 0x80030000
[ 1453.074798]    Transaction Type      : RD  - Read, Incrementing
[ 1453.074912]    Error Code            : SLV
[ 1453.074986]    Error Source          : Target
[ 1453.075064]    Error Description     : Target error detected by CBB slave
[ 1453.075199]    Packet header Lock    : 0
[ 1453.075277]    Packet header Len1    : 3
[ 1453.075385]    NOC protocol version  : version >= 2.7
[ 1453.075489]  ErrLog1                 : 0x157600
[ 1453.075572]  ErrLog2                 : 0x0
[ 1453.075636]    RouteId               : 0x157600
[ 1453.075711]    InitFlow              : cpu_p_i/I/0
[ 1453.075794]    Targflow              : cbb_t/T/0
[ 1453.075872]    TargSubRange          : 27
[ 1453.075945]    SeqId                 : 0
[ 1453.076008]  ErrLog3                 : 0x5c01814
[ 1453.076081]  ErrLog4                 : 0x0
[ 1453.076146]    Address accessed      : 0x15c01814
[ 1453.076319]  ErrLog5                 : 0x387e31
[ 1453.076544]    Master ID             : RCE
[ 1453.076776]    Security Group(GRPSEC): 0x3f
[ 1453.077790]    Cache                 : 0x1 -- Bufferable
[ 1453.081990]    Protection            : 0x1 -- Privileged, Secure, Data Access
[ 1453.088203]    FALCONSEC             : 0x0
[ 1453.091609]    Virtual Queuing Channel(VQC): 0x0
[ 1453.096353]  **************************************
[ 1453.101544] CPU:0, Error:cbb-noc@0x2300000,irq=15
[ 1453.105959] **************************************
[ 1453.110944] CPU:0, Error:cbb-noc
[ 1453.113926]  Error Logger            : 0
[ 1453.117254]  ErrLog0                 : 0x80030000
[ 1453.120834]    Transaction Type      : RD  - Read, Incrementing
[ 1453.126170]    Error Code            : SLV
[ 1453.129325]    Error Source          : Target
[ 1453.133000]    Error Description     : Target error detected by CBB slave
[ 1453.139566]    AXI2APB_5 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[ 1453.147176]    Packet header Lock    : 0
[ 1453.150850]    Packet header Len1    : 3
[ 1453.154521]    NOC protocol version  : version >= 2.7
[ 1453.159250]  ErrLog1                 : 0x9528aa
[ 1453.162834]  ErrLog2                 : 0x0
[ 1453.165463]    RouteId               : 0x9528aa
[ 1453.168789]    InitFlow              : rce_p2ps/I/rce_p2ps
[ 1453.173251]    Targflow              : host1x_p2pm/T/host1x_p2pm
[ 1453.178321]    TargSubRange          : 20
[ 1453.181557]    SeqId                 : 0
[ 1453.184357]  ErrLog3                 : 0x1814
[ 1453.187333]  ErrLog4                 : 0x0
[ 1453.189985]    Address accessed      : 0x15c01814
[ 1453.194682]  ErrLog5                 : 0x2af0fc71
[ 1453.198182]    Non-Modify            : 0x1
[ 1453.201595]    AXI ID                : 0x55
[ 1453.204488]    Master ID             : RCE
[ 1453.207830]    Security Group(GRPSEC): 0x3f
[ 1453.212009]    Cache                 : 0x1 -- Bufferable
[ 1453.216209]    Protection            : 0x3 -- Privileged, Non-Secure, Data Access
[ 1453.223033]    FALCONSEC             : 0x0
[ 1453.226183]    Virtual Queuing Channel(VQC): 0x0
[ 1453.230564]  **************************************
[ 1453.235980] Host read timeout at address 1814
[ 1453.240361] [RCE] VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.VM0 activating.VM0 deactivating.*** DATA ABORT EXCEPTION ***
[ 1453.240373] [RCE] R0:        15c00000        R1:     00001814        R2:     00008010        R3:     0000000a
[ 1453.349769] [RCE] R4:        0bcd0188        R5:     00000000        R6:     00000000        R7:     799ce800
[ 1453.349795] [RCE] R8:        0bcc27b0        R9:     0bcc27b2        R10:    0bcc27a8        R11:    00055ac0
[ 1453.349806] [RCE] R12:       0008e575        SP:     0bcc2768        LR:     0bcaaa2c        PC:     0bcaaa48
[ 1453.349813] [RCE] SPSR:      6000011f
[ 1453.349822] [RCE] DFSR:      00001008        DFAR:   15c01814        ADFSR:  00500000
[ 1453.349830] [RCE] IFSR:      00000000        IFAR:   00000000        AIFSR:  00000000
[ 1457.217836]  bc00000.rtcpu:hsp-vm1: request 0x42b640f4: response timeout
[ 1459.233810]  bc00000.rtcpu:hsp-vm1: request 0x42b640f4: response timeout
[ 1459.234004] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 2/3
[ 1459.341767] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 1460.321843] tegra194-vi5 15c10000.vi: capture control message timed out
[ 1460.322240] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
[ 1461.345821] tegra194-vi5 15c10000.vi: capture control message timed out
[ 1461.346048] tegra194-vi5 15c10000.vi: csi_stream_release: failed to disable nvcsi tpg on stream 4 virtual channel 0
And gstreamer windows exits automatically after re-launching.
I would suggest using v4l2-ctl to verify the driver and HW first.
Looks like need to adjust the size by driver instead of device tree.
