Hi.
I have captured the trace log.
At first glance it looks like there are no errors, but can you find the error somewhere?
$v4l2-ctl -d /dev/video0 --set-fmt-video width=720,height=576 --stream-mmap --stream-count=10 --stream-to=f20.raw
root@jetson-desktop:~# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 154/154 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _---=> hardirq/softirq
|| / _--=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-11441 [003] .... 2686.749031: tegra_channel_open: vi-output, adv7280 6-0021
v4l2-ctl-11441 [000] .... 2686.752566: tegra_channel_set_power: adv7280 6-0021 : 0x1
v4l2-ctl-11441 [000] .... 2686.756719: tegra_channel_set_power: nvcsi--1 : 0x1
v4l2-ctl-11441 [000] .... 2686.756737: csi_s_power: enable : 0x1
vi-output, adv7-11442 [003] … 2686.766375: tegra_channel_set_stream: enable : 0x1
vi-output, adv7-11442 [003] … 2686.768438: tegra_channel_set_stream: nvcsi–1 : 0x1
vi-output, adv7-11442 [003] … 2686.768441: csi_s_stream: enable : 0x1
vi-output, adv7-11442 [003] … 2686.768473: tegra_channel_set_stream: adv7280 6-0021 : 0x1
vi-output, adv7-11442 [003] … 2686.788159: tegra_channel_capture_frame: sof:2686.635396787
vi-output, adv7-11442 [001] … 2686.809218: tegra_channel_capture_frame: sof:2686.655351318
vi-output, adv7-11442 [000] … 2686.828120: tegra_channel_capture_frame: sof:2686.675201266
vi-output, adv7-11442 [000] … 2686.848991: tegra_channel_capture_frame: sof:2686.695481214
vi-output, adv7-11442 [000] … 2686.868976: tegra_channel_capture_frame: sof:2686.715508453
vi-output, adv7-11442 [001] … 2686.890475: tegra_channel_capture_frame: sof:2686.735176110
vi-output, adv7-11442 [000] … 2686.908124: tegra_channel_capture_frame: sof:2686.755200693
vi-output, adv7-11442 [002] … 2686.929017: tegra_channel_capture_frame: sof:2686.775462933
vi-output, adv7-11442 [002] … 2686.948187: tegra_channel_capture_frame: sof:2686.795200328
vi-output, adv7-11442 [002] … 2686.968312: tegra_channel_capture_frame: sof:2686.815158558
vi-output, adv7-11442 [002] … 2686.988033: tegra_channel_capture_frame: sof:2686.835146110
vi-output, adv7-11442 [002] … 2687.008020: tegra_channel_capture_frame: sof:2686.855127724
vi-output, adv7-11442 [002] … 2687.028381: tegra_channel_capture_frame: sof:2686.875291422
vi-output, adv7-11442 [001] … 2687.050034: tegra_channel_capture_frame: sof:2686.895396995
vi-output, adv7-11442 [002] … 2687.068424: tegra_channel_capture_frame: sof:2686.915182151
vi-output, adv7-11442 [001] … 2687.088940: tegra_channel_capture_frame: sof:2686.935087151
vi-output, adv7-11442 [000] … 2687.108284: tegra_channel_capture_frame: sof:2686.955217985
vi-output, adv7-11442 [000] … 2687.128799: tegra_channel_capture_frame: sof:2686.975346995
vi-output, adv7-11442 [000] … 2687.148803: tegra_channel_capture_frame: sof:2686.995369912
vi-output, adv7-11442 [000] … 2687.168760: tegra_channel_capture_frame: sof:2687.15328610
vi-output, adv7-11442 [001] … 2687.190015: tegra_channel_capture_frame: sof:2687.35351057
vi-output, adv7-11442 [000] … 2687.208214: tegra_channel_capture_frame: sof:2687.55142203
vi-output, adv7-11442 [001] … 2687.229376: tegra_channel_capture_frame: sof:2687.75201110
vi-output, adv7-11442 [000] … 2687.247969: tegra_channel_capture_frame: sof:2687.95124339
vi-output, adv7-11442 [002] … 2687.270173: tegra_channel_capture_frame: sof:2687.115185120
vi-output, adv7-11442 [001] … 2687.289243: tegra_channel_capture_frame: sof:2687.135100537
vi-output, adv7-11442 [000] … 2687.308005: tegra_channel_capture_frame: sof:2687.155053193
vi-output, adv7-11442 [000] … 2687.328778: tegra_channel_capture_frame: sof:2687.175261578
trace_log.txt (15.3 KB)
