Hi.
I set fmt-> width = 400.
However, the capture results did not improve.
↓confirm
jetson@jetson-desktop:~/source/adv7280$ v4l2-ctl -d /dev/video0 --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, adv7280 6-0021
Bus info : platform:54080000.vi:0
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: no signal)
DV timings:
Active width: 0
Active height: 0
Total width: 0
Total height: 0
Frame format: progressive
Polarities: -vsync -hsync
Pixelclock: 0 Hz
Horizontal frontporch: 0
Horizontal sync: 0
Horizontal backporch: 0
Vertical frontporch: 0
Vertical sync: 0
Vertical backporch: 0
Standards:
Flags:
Format Video Capture:
Width/Height : 400/576
Pixel Format : ‘UYVY’
Field : Alternating
Bytes per Line : 832
Size Image : 479232
Colorspace : SMPTE 170M
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :User Controls
brightness 0x00980900 (int) : min=-128 max=127 step=1 default=0 value=0 flags=slider contrast 0x00980901 (int) : min=0 max=255 step=1 default=128 value=128 flags=slider saturation 0x00980902 (int) : min=0 max=255 step=1 default=128 value=128 flags=slider hue 0x00980903 (int) : min=-127 max=128 step=1 default=0 value=0 flags=slider fast_switching 0x00981970 (bool) : default=0 value=0Camera Controls
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0 override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0 height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1 size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0 write_isp_format 0x009a2068 (bool) : default=0 value=0 sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload low_latency_mode 0x009a206d (bool) : default=0 value=0 sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=30 flags=read-only
↓dmesg
[ 156.778377] vi 54080000.vi: tegra_channel_error_status:error 4000 frame 319
[ 156.785368] here 3333333333
[ 156.788308] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00004015
[ 156.788318] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 156.788322] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 156.788365] vi 54080000.vi: cil_settingtime was autocalculated
[ 156.788369] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 156.788381] single thread enable !!!
