As title, Does Jetnano support above solution?
Yes, Nano can support GMSL camera without virtual channel.
Dear Shane,
Thank you for your reply ,
I have implement camera driver for MAX9286 by refer below guide:
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3231/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fcamera_sensor_prog.html%23
Is it right way to develop a driver for MAX9286?
What’s the meaning of “without virtual channel”, Could you give me some more information about it?
By the way , our hardware connection is Jetson Nano <–Mipi–> MAX9286 Coax dev kit <–4 GMSL Camera (with MAX96705 Deserializer and AP0101 & AR0143)
Thanks a lot.
One more thing ,
Does Jetson nano support virtual channel ?
As Guide said ,
" •Jetson AGX Xavier series and Jetson TX2 series also support the MIPI CSI virtual channel feature. The virtual channel is a unique channel identifier used for multiplexed sensor streams sharing the same CSI port/brick and CSI stream through supported GMSL (Gigabit Multimedia Serial Link) aggregators.
•GMSL + VC capture is validated on Jetson AGX Xavier series and Jetson TX2 series using the nvgstcapture application. The reference GMSL module (MAX9295-serializer/MAX9296-deserializer/IMX390-sensor) is used for validation purposes."
Does it mean only “Jetson AGX Xavier series and Jetson TX2 series” support Virtual Channel , and reference “MAX9295-serializer/MAX9296-deserializer/IMX390-sensor” is enough for my development?
Thanks .
TX1/Nano(t210) not support VC others support it.
OK, I see.
Do you think reference “MAX9295-serializer/MAX9296-deserializer/IMX390-sensor” is enough for my development?
But actually i cant find dts related modification of above serdes solution.
Thanks a lot.
The reference MAX9295/Max9296 are for the virtual channel referencing. You may need to consult with vendor to get the nonoe VC driver configure.
Do you mean the serializer/deserializer vendor?
Yes
Seems serializer/deserializer only provide register configuration , not include platform driver.
Currently , i develop the driver for max9286 on Jetson nano by following IMX219 driver (trust max9286 as a sensor, AR0143 and AP0101 dont need any configuration)
Do you think it’s a feasible way for my situation?
Hope your kindness reply.
Thanks a lot.
Yes, I think there’s should be without problem if the SER/DES configure well.
OK, thanks .
By the way , how to identifier a driver whether use VC or not?
Maybe the driver have some information for the vc-id
After i configure MAX9286 and MAX96705 register as normal and try to use v4l2 capture video from /dev/video0 ,
it occur timeout .
As check the kernel log, it shows :
[ 80.517278] max9286 6-0048: max9286_set_mode:
[ 80.517284] max9286 6-0048: max9286_start_streaming:
[ 80.517653] ## [max9286_i2c_write():max9286.c:143 ] addr:0x90, reg:0x1b, read_val:0xf
[ 80.526174] ## [max9286_i2c_write():max9286.c:143 ] addr:0x90, reg:0x32, read_val:0xaa
[ 80.534894] ## [max9286_i2c_write():max9286.c:143 ] addr:0x90, reg:0x33, read_val:0xaa
[ 80.543692] ## [max9286_i2c_write():max9286.c:143 ] addr:0x8e, reg:0x04, read_val:0x87
[ 80.658744] ## [max9286_i2c_write():max9286.c:143 ] addr:0x90, reg:0x15, read_val:0x8b
[ 80.890440] video4linux video0: frame start syncpt timeout!0
[ 81.098339] video4linux video0: frame start syncpt timeout!0
[ 81.306209] video4linux video0: frame start syncpt timeout!0
[ 81.514251] video4linux video0: frame start syncpt timeout!0
[ 81.722109] video4linux video0: frame start syncpt timeout!0
[ 81.934084] video4linux video0: frame start syncpt timeout!0
[ 82.142114] video4linux video0: frame start syncpt timeout!0
[ 82.350044] video4linux video0: frame start syncpt timeout!0
[ 82.557960] video4linux video0: frame start syncpt timeout!0
Could you help to find any clue from above logs to debug the issue?
Thanks a lot.
You need to enable the debug print of the csi2_fops.c/vi2_fops.c
As enable DEBUG of csi2_fops.c/vi2_fops.c , and try to capture video, log shows like below.
[ 154.904539] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
[ 154.904601] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 154.904651] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 154.904697] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 154.904919] vi 54080000.vi: cil_settingtime was autocalculated
[ 154.904959] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 155.106576] video4linux video0: frame start syncpt timeout!0
Does it have any incorrect configuration of csi/vi ?
The log show the data and clk lane control error.
Have a check the TRM for the detail information.
Dear Shane ,
Do you mean by setting pixel clk for MAX9286?
Or other configuration of clock?
Thanks a lot.
It’s could be the csi lanes configure problem.
Dear Shane,
As check TRM, i found that TEGRA_CSI_CILX_STATUS 0x00040041 means:
CILA_CLK_LANE_CTRL_ERR
CILA_DATA_LANE0_CTRL_ERR
CILA_DATA_LANE1_CTRL_ERR
But where should i confige csi lanes on Jetson nano ?
Attached my dts file which refer imx219 dts.
Do i need modify something in dtsi?
include <dt-bindings/media/camera.h>
include <dt-bindings/platform/t210/t210.h>/ {
host1x {
vi_base: vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
max9286_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&max9286_csi_out0>;
};csi_base: nvcsi { num-channels = <1>; #address-cells = <1>; #size-cells = <0>; csi_chan0: channel@0 { reg = <0>; ports { #address-cells = <1>; #size-cells = <0>; csi_chan0_port0: port@0 { reg = <0>; max9286_csi_in0: endpoint@0 { port-index = <0>; bus-width = <2>; remote-endpoint = <&max9286_out0>; }; }; csi_chan0_port1: port@1 { reg = <1>; max9286_csi_out0: endpoint@1 { remote-endpoint = <&max9286_vi_in0>; }; }; }; }; }; i2c@546c0000 { max9286_single_cam0: max9286_a@48 { compatible = "maxim,max9286"; /* I2C device address */ reg = <0x48>; /* V4L2 device node location */ devnode = "video0"; /* Physical dimensions of sensor */ physical_w = "3.680"; physical_h = "2.760"; sensor_model = "max9286"; use_sensor_mode_id = "true"; /** * ==== Modes ==== * A modeX node is required to support v4l2 driver * implementation with NVIDIA camera software stack * * == Signal properties == * * phy_mode = ""; * PHY mode used by the MIPI lanes for this device * * tegra_sinterface = ""; * CSI Serial interface connected to tegra * Incase of virtual HW devices, use virtual * For SW emulated devices, use host * * pix_clk_hz = ""; * Sensor pixel clock used for calculations like exposure and framerate * * readout_orientation = "0"; * Based on camera module orientation. * Only change readout_orientation if you specifically * Program a different readout order for this mode * * == Image format Properties == * * active_w = ""; * Pixel active region width * * active_h = ""; * Pixel active region height * * pixel_t = ""; * The sensor readout pixel pattern * * line_length = ""; * Pixel line length (width) for sensor mode. * * == Source Control Settings == * * Gain factor used to convert fixed point integer to float * Gain range [min_gain/gain_factor, max_gain/gain_factor] * Gain step [step_gain/gain_factor is the smallest step that can be configured] * Default gain [Default gain to be initialized for the control. * use min_gain_val as default for optimal results] * Framerate factor used to convert fixed point integer to float * Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor] * Framerate step [step_framerate/framerate_factor is the smallest step that can be configured] * Default Framerate [Default framerate to be initialized for the control. * use max_framerate to get required performance] * Exposure factor used to convert fixed point integer to float * For convenience use 1 sec = 1000000us as conversion factor * Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor] * Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured] * Default Exposure Time [Default exposure to be initialized for the control. * Set default exposure based on the default_framerate for optimal exposure settings] * * gain_factor = ""; (integer factor used for floating to fixed point conversion) * min_gain_val = ""; (ceil to integer) * max_gain_val = ""; (ceil to integer) * step_gain_val = ""; (ceil to integer) * default_gain = ""; (ceil to integer) * Gain limits for mode * * exposure_factor = ""; (integer factor used for floating to fixed point conversion) * min_exp_time = ""; (ceil to integer) * max_exp_time = ""; (ceil to integer) * step_exp_time = ""; (ceil to integer) * default_exp_time = ""; (ceil to integer) * Exposure Time limits for mode (sec) * * framerate_factor = ""; (integer factor used for floating to fixed point conversion) * min_framerate = ""; (ceil to integer) * max_framerate = ""; (ceil to integer) * step_framerate = ""; (ceil to integer) * default_framerate = ""; (ceil to integer) * Framerate limits for mode (fps) * * embedded_metadata_height = ""; * Sensor embedded metadata height in units of rows. * If sensor does not support embedded metadata value should be 0. */ mode0 { /* MAX9286_MODE_1280x720_120FPS */ mclk_khz = "24000"; num_lanes = "2"; tegra_sinterface = "serial_a"; phy_mode = "DPHY"; discontinuous_clk = "yes"; dpcm_enable = "false"; cil_settletime = "0"; active_w = "1280"; active_h = "720"; mode_type = "yuv"; csi_pixel_bit_depth = "8"; pixel_phase = "uyvy"; readout_orientation = "90"; line_length = "3448"; inherent_gain = "1"; mclk_multiplier = "9.33"; pix_clk_hz = "169600000"; gain_factor = "16"; framerate_factor = "1000000"; exposure_factor = "1000000"; min_gain_val = "16"; /* 1.00x */ max_gain_val = "170"; /* 10.66x */ step_gain_val = "1"; default_gain = "16"; /* 1.00x */ min_hdr_ratio = "1"; max_hdr_ratio = "1"; min_framerate = "2000000"; /* 2.0 fps */ max_framerate = "120000000"; /* 120.0 fps */ step_framerate = "1"; default_framerate = "120000000"; /* 120.0 fps */ min_exp_time = "13"; /* us */ max_exp_time = "683709"; /* us */ step_exp_time = "1"; default_exp_time = "2495"; /* us */ embedded_metadata_height = "2"; }; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; max9286_out0: endpoint { port-index = <0>; bus-width = <2>; remote-endpoint = <&max9286_csi_in0>; }; }; }; }; }; };};
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;/** * Physical settings to calculate max ISO BW * * num_csi_lanes = <>; * Total number of CSI lanes when all cameras are active * * max_lane_speed = <>; * Max lane speed in Kbit/s * * min_bits_per_pixel = <>; * Min bits per pixel * * vi_peak_byte_per_pixel = <>; * Max byte per pixel for the VI ISO case * * vi_bw_margin_pct = <>; * Vi bandwidth margin in percentage * * max_pixel_rate = <>; * Max pixel rate in Kpixel/s for the ISP ISO case * * isp_peak_byte_per_pixel = <>; * Max byte per pixel for the ISP ISO case * * isp_bw_margin_pct = <>; * Isp bandwidth margin in percentage */ num_csi_lanes = <2>; max_lane_speed = <1500000>; min_bits_per_pixel = <8>; vi_peak_byte_per_pixel = <2>; vi_bw_margin_pct = <25>; max_pixel_rate = <240000>; isp_peak_byte_per_pixel = <5>; isp_bw_margin_pct = <25>; /** * The general guideline for naming badge_info contains 3 parts, and is as follows, * The first part is the camera_board_id for the module; if the module is in a FFD * platform, then use the platform name for this part. * The second part contains the position of the module, ex. "rear" or "front". * The third part contains the last 6 characters of a part number which is found * in the module's specsheet from the vendor. */ modules { cam_module0: module0 { badge = "porg_front_RBPCV2"; position = "front"; orientation = "1"; cam_module0_drivernode0: drivernode0 { pcl_id = "v4l2_sensor"; devname = "max9286 6-0048"; proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/max9286_a@48"; }; }; };};
