Hello everyone,
I would like to ask that, I want to display the count text on each frame.
Therefore in my custom plugin, I have added the display meta to the frame meta after populating the display meta structure with the text i want. However, frame is rendered at the end without my added display meta for the text.
My current logic to achieve that is mentioned below:
In my gst-plugin which is of GSTBaseTransform type , I am reading each framemeta present in a batch which is being received in my plugin’s transform_ip () function.
My logic of adding the display meta to each frame is :
static void
attach_displaymetadata_full_frame (GstMyCount * mycount, NvDsFrameMeta * frame_meta, guint Source_id,
gdouble scale_ratio, guint batch_id)
NvDsBatchMeta *batch_meta = frame_meta->base_meta.batch_meta;
NvDsDisplayMeta *display_meta = NULL;
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
nvds_acquire_meta_lock (batch_meta);
NvOSD_TextParams & text_params = display_meta->text_params[0];
text_params.x_offset = 500;
text_params.y_offset = 500;
// Font face, size and color
text_params.font_params.font_name = (char *)"Serif";
text_params.font_params.font_size = 11;
text_params.font_params.font_color = (NvOSD_ColorParams) {1, 1, 1, 1};
// display_text required heap allocated memory
text_params.display_text = g_strdup ("Count");
// Set black background for the text
text_params.set_bg_clr = 1;
text_params.text_bg_clr = (NvOSD_ColorParams) {0, 0, 0, 1};
nvds_add_display_meta_to_frame( frame_meta, display_meta);
nvds_release_meta_lock (batch_meta);
Notice: data is getting added to the framemeta(checked) but not being rendered on the display.
Looking forward to get some help from the nvidia’s deepstream library maintainers, as to what am i missing here.
