When I try to modify the number of display units of deepstream, the line drawing and display text will not take effect, and a memory error will occur when it exceeds 32. The source code macro is defined as follows
#define MAX_ ELEMENTS_ IN_ DISPLAY_ META 16
#define MAX_ ELEMENTS_ IN_ DISPLAY_ Meta 32 / / program error
#define MAX_ ELEMENTS_ IN_ DISPLAY_ Meta 20 / / text and line drawing cannot be displayed
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
