Hello NVIDIA Developers,
I use AGX to recieve the 4-lane MIPI csi signal without i2c from Xilinx FPGA .I have followed some similar implementationshttps://forums.developer.nvidia.com/t/jetson-agx-xavier-mipi-csi-2-without-i2c-from-fpga/165969 ,and can detect the /dev/video0.
But now ,I have a problem that I can not detect the CSI singal, the message as following:
[ 67.918986] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 67.919144] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 67.919299] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 67.922968] Unable to handle kernel NULL pointer dereference at virtual address 00000010
[ 67.923153] Mem abort info:
[ 67.923242] ESR = 0x96000005
[ 67.923307] Exception class = DABT (current EL), IL = 32 bits
[ 67.923413] SET = 0, FnV = 0
[ 67.923473] EA = 0, S1PTW = 0
[ 67.923560] Data abort info:
[ 67.923616] ISV = 0, ISS = 0x00000005
[ 67.923684] CM = 0, WnR = 0
[ 67.923748] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc6a51ec000
[ 67.923860] [0000000000000010] *pgd=0000000000000000, *pud=0000000000000000
[ 67.924011] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 67.924111] Modules linked in: bnep xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack fuse br_netfilter zram overlay binfmt_misc bluedroid_pm userspace_alert nvgpu ip_tables x_tables
[ 67.934947] CPU: 6 PID: 8404 Comm: vi-output, ov56 Not tainted 4.9.253 #3
[ 67.941333] Hardware name: Jetson-AGXi (DT)
[ 67.945794] task: ffffffc6ad160000 task.stack: ffffffc68a6bc000
[ 67.951753] PC is at _raw_write_lock+0x30/0x58
[ 67.956035] LR is at destroy_buffer_table+0x40/0xd8
[ 67.961020] pc : [<ffffff8008f6db50>] lr : [<ffffff8008b4e6e8>] pstate: 20c00045
[ 67.968280] sp : ffffffc68a6bfc70
[ 67.971520] x29: ffffffc68a6bfc70 x28: 0000000000000000
[ 67.977027] x27: 0000000000000000 x26: 0000000000000000
[ 67.982541] x25: 0000000000000010 x24: 0000000000000098
[ 67.988315] x23: 0000000000000018 x22: ffffff8009087830
[ 67.993139] x21: 0000000000000000 x20: ffffffc684a48000
[ 67.998303] x19: 0000000000000010 x18: 00000000000012e2
[ 68.004241] x17: 0000000000000002 x16: 0000000000000003
[ 68.010014] x15: 0000000000000297 x14: 0000000000075a53
[ 68.015541] x13: ffffff8008f897bc x12: 00000000000731fd
[ 68.021231] x11: 0000000000000000 x10: 0000000000000a10
[ 68.027163] x9 : ffffffc68a6bfa80 x8 : 0000000000000000
[ 68.032940] x7 : ffffffc65ec4a640 x6 : ffffffc6857f0bc1
[ 68.038452] x5 : ffffff800852d904 x4 : ffffffbf1a15fc10
[ 68.043542] x3 : 0000000000000000 x2 : ffffffc6857f0bc0
[ 68.048878] x1 : 0000000000000000 x0 : 0000000080000000
[ 68.055609] Process vi-output, ov56 (pid: 8404, stack limit = 0xffffffc68a6bc000)
[ 68.062786] Call trace:
[ 68.065152] [<ffffff8008f6db50>] _raw_write_lock+0x30/0x58
[ 68.070225] [<ffffff8008b4e6e8>] destroy_buffer_table+0x40/0xd8
[ 68.076087] [<ffffff8008b4098c>] vi_capture_shutdown+0xd4/0x130
[ 68.081425] [<ffffff8008b40fe4>] vi_channel_close_ex+0x34/0x88
[ 68.087285] [<ffffff8008b424f0>] vi5_channel_error_recover+0x48/0x1c8
[ 68.093234] [<ffffff8008b375c0>] tegra_channel_error_recover+0x58/0x90
[ 68.099358] [<ffffff8008b42db0>] tegra_channel_kthread_capture_dequeue+0xf8/0x1c0
[ 68.106276] [<ffffff80080db09c>] kthread+0xec/0xf0
[ 68.110909] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[ 68.116163] ---[ end trace 1d8deaa5d5953665 ]---
[ 68.134032] note: vi-output, ov56[8404] exited with preempt_count 1
[ 96.296899] L1SS : srcID 2 destID 1 cmdID 9 ClassID 1 is_resp=0
[ 96.297052] L1SS : cmd_resp_l1_user_rcv_FuSa_state_notification FuSa State = 2
[ 97.317778] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 97.317961] Mem abort info:
[ 97.318021] ESR = 0x96000005
[ 97.318120] Exception class = DABT (current EL), IL = 32 bits
[ 97.318225] SET = 0, FnV = 0
[ 97.318288] EA = 0, S1PTW = 0
[ 97.318347] Data abort info:
[ 97.318415] ISV = 0, ISS = 0x00000005
[ 97.318487] CM = 0, WnR = 0
[ 97.318598] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc6b0b2b000
[ 97.318730] [0000000000000000] *pgd=0000000000000000, *pud=0000000000000000
[ 97.318905] Internal error: Oops: 96000005 [#2] PREEMPT SMP
[ 97.319008] Modules linked in: bnep xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack fuse br_netfilter zram overlay binfmt_misc bluedroid_pm userspace_alert nvgpu ip_tables x_tables
[ 97.320327] CPU: 7 PID: 8402 Comm: v4l2-ctl Tainted: G D 4.9.253 #3
[ 97.320883] Hardware name: Jetson-AGXi (DT)
[ 97.323525] task: ffffffc66c7ff000 task.stack: ffffffc6b15d8000
[ 97.329049] PC is at exit_creds+0x2c/0x78
[ 97.333502] LR is at __put_task_struct+0x4c/0x140
[ 97.338244] pc : [<ffffff80080de15c>] lr : [<ffffff80080aee9c>] pstate: 60400045
[ 97.345491] sp : ffffffc6b15dba00
[ 97.348477] x29: ffffffc6b15dba00 x28: ffffffc66c7ff000
[ 97.353998] x27: ffffff8008f82000 x26: ffffffc668d49080
[ 97.359509] x25: ffffffc68a0a9fe8 x24: ffffffc6ce4a5598
[ 97.365531] x23: 0000000000000001 x22: ffffffc6bc58a018
[ 97.370268] x21: ffffffc6ad160030 x20: 0000000000000000
[ 97.375548] x19: ffffffc6ad160000 x18: 0000000000000000
[ 97.381206] x17: 0000007fb16c8e10 x16: ffffff8008274b68
[ 97.387046] x15: 0000000000000000 x14: 0000000000080f54
[ 97.392574] x13: 00000000000045ea x12: 071c71c71c71c71c
[ 97.398335] x11: 000000000000000b x10: 0000000000000a10
[ 97.404108] x9 : ffffffc6b15db850 x8 : ffffffc66c7ffa70
[ 97.409885] x7 : fefefeff646c606d x6 : 00000000d7065bf2
[ 97.415405] x5 : 0000000000000800 x4 : 0000000000000000
[ 97.420480] x3 : 00000000000000e1 x2 : 0000000000000000
[ 97.426066] x1 : 0000000000000000 x0 : 00000000ffffffff
[ 97.432827] Process v4l2-ctl (pid: 8402, stack limit = 0xffffffc6b15d8000)
[ 97.439461] Call trace:
[ 97.441832] [<ffffff80080de15c>] exit_creds+0x2c/0x78
[ 97.446382] [<ffffff80080aee9c>] __put_task_struct+0x4c/0x140
[ 97.451719] [<ffffff80080dbbfc>] kthread_stop+0x1e4/0x1e8
[ 97.456797] [<ffffff8008b42708>] vi5_channel_stop_kthreads+0x40/0x58
[ 97.463175] [<ffffff8008b427ec>] vi5_channel_stop_streaming+0xcc/0xd0
[ 97.469303] [<ffffff8008b3445c>] tegra_channel_stop_streaming+0x34/0x48
[ 97.475255] [<ffffff8008b2c774>] __vb2_queue_cancel+0x34/0x188
[ 97.481115] [<ffffff8008b2dc9c>] vb2_core_queue_release+0x2c/0x58
[ 97.486977] [<ffffff8008b3031c>] _vb2_fop_release+0x84/0xa0
[ 97.492052] [<ffffff8008b35df4>] tegra_channel_close+0x64/0x140
[ 97.497746] [<ffffff8008b096e8>] v4l2_release+0x48/0xa0
[ 97.502820] [<ffffff800825dcb8>] __fput+0x90/0x1d0
[ 97.507886] [<ffffff800825de70>] ____fput+0x20/0x30
[ 97.512444] [<ffffff80080d8dac>] task_work_run+0xbc/0xd8
[ 97.517955] [<ffffff80080b8408>] do_exit+0x2e0/0xa88
[ 97.523111] [<ffffff80080b8c40>] do_group_exit+0x40/0xa8
[ 97.528454] [<ffffff80080c64ec>] get_signal+0xbc/0x750
[ 97.533360] [<ffffff800808add8>] do_signal+0x130/0x500
[ 97.538864] [<ffffff800808b320>] do_notify_resume+0x90/0xb0
[ 97.544464] [<ffffff800808379c>] work_pending+0x8/0x10
[ 97.549542] ---[ end trace 1d8deaa5d5953666 ]---
[ 97.568463] Fixing recursive fault but reboot is needed!
I am completely new to this field, and I have looked up many similar questions online, but still have no clue. I want to know if there is any problem with my driver.
Any help or feedback would be greatly apprecited.
