- Basic Info:
hardware: jetson-agx-orin-devkit
JetPack : 6.2
Jetson Linux : 36.4.3
connect spkeaker on HD audio header pin2 and pin9
dts in system:
proc.dts.txt (323.0 KB)
kernel log:
kernel.txt (64.7 KB)
mixer:
mixer.txt (62.2 KB)
component:
components.txt (527 Bytes)
clock:
clock.txt (42.4 KB)
pinmux:
pinmux_c300000.txt (6.3 KB)
pinmux_2340000.txt (31.4 KB)
codec regdump:
codec_regdump.txt (2.9 KB)
- Qeustion:
reflink Audio Setup and Development — NVIDIA Jetson Linux Developer Guide
on devkit, using default JP6.2 source code, using command below, no sound
amixer -c APE cset name=“I2S1 Mux” “ADMAIF1”
#amixer -c APE cset name=“I2S1 codec frame mode” “dsp-a”
amixer -c APE cset name=“CVB-RT HP Playback Volume” 30
amixer -c APE cset name=“CVB-RT Stereo DAC MIXR DAC R1 Switch” “on”
amixer -c APE cset name=“CVB-RT Stereo DAC MIXL DAC L1 Switch” “on”
amixer -c APE cset name=“CVB-RT HP R Playback Switch” “on”
amixer -c APE cset name=“CVB-RT HP L Playback Switch” “on”
aplay -D hw:APE,0 test.wav
- Current status
root@tegra:~# amixer -c APE cset name=“CVB-RT HP Playback Volume” 30
amixer: Cannot find the given element from control sysdefault:1
there is no CVB mixer
root@tegra:~# amixer -c APE controls | grep CVB
root@tegra:~#
sound cards info
root@tegra:~# cat /proc/asound/cards
0 [HDA ]: tegra-hda - NVIDIA Jetson AGX Orin HDA
NVIDIA Jetson AGX Orin HDA at 0x3518000 irq 124
1 [APE ]: tegra-ape - NVIDIA Jetson AGX Orin APE
NVIDIA-NVIDIAJetsonAGXOrinDeveloperKit-NotSpecified-Jetson
rtl5640 sound card
root@tegra:~# lsmod | grep 5640
snd_soc_rt5640 126976 0
snd_soc_rl6231 16384 1 snd_soc_rt5640
kernel log no asoc content
root@tegra:~# dmesg | grep “ASoC”
root@tegra:~#
so the problem may lies in the no CVB mixer? how to fix this?
