Hi All,
We are trying to test Jetson AGX Orin Dev kit audio ( It has devkit BSP only , not modified) , But it is not working as expected .
2 pin - GND of headphone
5 pin - headphone out left side
9 pin - headphone out right side.
In sound setting we made sure analog audio selection
Any configuration is required ?
Any input please…
Hi vardhaman.k,
Can you confirm if your Dev Kit has onboard audio codec?
Please dump following info on target:
$ i2cdetect -y -r 31e0000.i2c
Also please share output of following:
* cat /sys/kernel/debug/asoc/components
* amixer -c APE controls
Above can help confirm if your board has onboard codec and its driver has been registered properly or not.
Thanks,
Sameer.
Hi Sameer, Any update on this ?
Hi Vardhaman,
Thanks for your logs
Perform below steps based on your environment.
Step 1: Without building BSP
On Host :
- Take backup of base DTB file.
- cd Linux_for_Tegra/kernel/dtb
- cp <file.dtb> <file.dtb>.bac
- Apply overlay and generate modified DTB
$ fdtoverlay -i <file.dtb> -o <file.dtb> tegra234-p3737-audio-codec-rt5640 .dtbo
For example: file.dtb => tegra234-p3701-xxxx-p3737-xxxx.dtb , use right dtb base file by referring the flash log.
Or
Step 2: (Apply DT changes in build env.)
Please apply the attached patches to enable onboard. RT5640 codec by default, build and flash the image.
enable_onboard_codec.diff (2.0 KB)
overlay.diff (1.5 KB)
Let us know if you still face issue in playback.
Hi @mkumard ,
Step1: I am getting no such file or directory. Logs attached with ls command response. (Step1_AudioExlore1)
hmecd001409@DSC:~/BSP/Osbourne_orin/Linux_for_Tegra/kernel/dtb$ cp tegra234-p3701-0004-p3737-0000.dtb tegra234-p3701-0004-p3737-0000.dtb.bac
hmecd001409@DSC:~/BSP/Osbourne_orin/Linux_for_Tegra/kernel/dtb$ fdtoverlay -i tegra234-p3701-0004-p3737-0000.dtb -o tegra234-p3701-0004-p3737-0000.dtb tegra234-p3737-audio-codec-rt5640.dtbo
Couldn’t open blob from ‘tegra234-p3737-audio-codec-rt5640.dtbo’: No such file or directory
Failed to read ‘tegra234-p3737-audio-codec-rt5640.dtbo’
Steps2: For 2nd steps to apply patches, not able to find “tegra234-p3737-overlay.dts” files. Downloaded from “Log in | NVIDIA Developer” But it came with dtb file.
Please can you share more info or file ?
Step1_AudioExlore1.txt (5.6 KB)
Hi Vardhaman,
Are you able to apply above patch?. If so it should enable codec on your board version. Can you give a try with build and flash.
Hi Mkumard,
Overlay patch did not apply. Only With enable_onboard_codec.diff patch able to enable audio and now audio coming.
Thanks lot Mkumard. :-)
Vardhaman,
Welcome!. Also please note in the next Jetpack release the audio codec will be enabled by default.
Thanks again.
