AGX Orin R39.2.1: J40 USB-C falls back to USB2 at boot and fails after replug
Title
Jetson AGX Orin Developer Kit R39.2.1: J40 Type-C falls back to USB 2.0 when RealSense D435i is connected before boot, then fails to re-enumerate after unplug/replug
Hardware
  • NVIDIA Jetson AGX Orin Developer Kit 64GB
  • Intel RealSense D435i RGB-D camera
  • Camera connected directly to the J40 USB Type-C port, near the 40-pin header
  • The same camera and USB-C cable work normally on the other Type-C port / fixed-host USB port
Software Environment
Jetson Linux / L4T:
# R39 (release), REVISION: 2.1, GCID: 46758480
BOARD: generic
DATE: Fri Aug 7 05:54:22 AM UTC 2026
Kernel:
Linux 6.8.12-1021-tegra
#1 SMP PREEMPT Thu Aug 6 21:56:04 PDT 2026
aarch64 GNU/Linux
BIOS:
39.2.1-gcid-46758480
Relevant NVIDIA packages are also all from the same R39.2.1 release:
nvidia-l4t-bootloader      39.2.1-20260806224157
nvidia-l4t-core            39.2.1-20260806224157
nvidia-l4t-kernel          6.8.12-tegra-39.2.1-20260806224157
nvidia-l4t-kernel-dtbs     6.8.12-tegra-39.2.1-20260806224157
nvidia-l4t-kernel-oot-modules
Therefore, the BIOS, bootloader, rootfs, kernel, and DTB appear to be aligned to R39.2.1.
Problem Description
I found a consistent behavior depending on whether the RealSense D435i is already connected to J40 when the Jetson boots.
Case 1: Camera is NOT connected during boot
  1. Boot the Jetson without the D435i connected to J40.
  2. Wait until Linux has fully booted.
  3. Connect the D435i to J40.
Result:
  • The D435i is correctly detected as USB 3.x SuperSpeed.
  • dmesg reports:
usb 2-2: new SuperSpeed USB device using tegra-xusb
usb 2-2: New USB device found, idVendor=8086, idProduct=0b3a
usb 2-2: Product: Intel(R) RealSense(TM) Depth Camera 435i
  • Hot-unplug and hot-plug continue to work normally afterward.
  • The camera continues to enumerate as USB 3.x.
This behavior is stable.
Case 2: Camera IS connected to J40 before power-on
  1. Power off the Jetson.
  2. Connect the D435i to J40.
  3. Power on the Jetson.
  4. Wait for Linux to boot.
Result:
The D435i is detected only as USB 2.0 / 480 Mbps.
lsusb -t:
/:  Bus 001.Port 001: Dev 001, Class=root_hub, Driver=tegra-xusb/4p, 480M
    |__ Port 001: Dev 004, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 001: Dev 004, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 001: Dev 004, If 2, Class=Video, Driver=uvcvideo, 480M
    |__ Port 001: Dev 004, If 3, Class=Video, Driver=uvcvideo, 480M
    |__ Port 001: Dev 004, If 4, Class=Video, Driver=uvcvideo, 480M
    |__ Port 001: Dev 004, If 5, Class=Human Interface Device, Driver=usbhid, 480M
The camera is present:
Bus 001 Device 004: ID 8086:0b3a Intel Corp. Intel(R) RealSense(TM) Depth Camera 435i
The kernel log confirms that the camera enumerates only as USB 2.0 High-Speed:
usb 1-1: new high-speed USB device number 4 using tegra-xusb
usb 1-1: New USB device found, idVendor=8086, idProduct=0b3a
usb 1-1: Product: Intel(R) RealSense(TM) Depth Camera 435i
usb 1-1: Manufacturer: Intel(R) RealSense(TM) Depth Camera 435i
However, the USB 3.x root hub itself is operating normally:
/:  Bus 002.Port 001: Dev 001, Class=root_hub,
    Driver=tegra-xusb/4p, 10000M
Another USB 3 hub on the same system is also successfully operating at 10 Gbps:
|__ Port 003: Dev 002, Class=Hub, Driver=hub/4p, 10000M
The boot log also shows:
tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
usb 2-3: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
Therefore, the overall Tegra xHCI USB 3 controller appears to be functional during the problematic boot.
Additional Important Behavior
After booting in the bad state described above:
  1. The D435i is initially detected as USB 2.0 / 480M.
  2. I unplug the D435i from J40.
The kernel correctly reports:
usb 1-1: USB disconnect, device number 4
  1. I reconnect the camera to J40.
At this point, the camera is not detected at all.
There is:
  • no new high-speed USB device
  • no new SuperSpeed USB device
  • no new USB enumeration message in dmesg
lsusb -t no longer shows the RealSense device.
However, the Type-C subsystem clearly detects that something has been reconnected.
After reconnecting the camera:
===== port1 =====
data_role: [host]
power_role: [source]
partner: YES
So J40 appears to have:
  • detected a Type-C partner
  • entered host data role
  • entered source power role
but the USB device is never passed through to the xHCI USB bus.
Before reconnecting, partner becomes NO, and after reconnecting it returns to YES.
Type-C / USB Role Observation
The J40-related Type-C port shows:
port1:
data_role: host
power_role: source
partner: YES
even in the state where the RealSense camera cannot be enumerated by USB.
This suggests that Type-C CC/partner detection and VBUS sourcing are working, while the actual USB data path is not being re-established.
Reproducibility
The behavior is strongly correlated with boot state:
Camera disconnected during boot
→ boot Linux
→ connect D435i to J40
→ USB 3 SuperSpeed works
→ later hot-plug also works
Camera already connected to J40 before boot
→ boot Linux
→ D435i enumerates as USB 2.0 / 480M
→ unplug D435i
→ reconnect D435i
→ Type-C partner is detected
→ no USB enumeration occurs
I can reproduce this behavior consistently.
Comparison With the Other Type-C Port
The same D435i and cable can operate as USB 3.x when connected to the other Type-C / fixed-host port.
Therefore, the camera and cable are capable of USB 3 operation.
The issue appears specific to J40 and its dual-role Type-C/OTG behavior.
Potentially Relevant Boot Messages
During boot I see dependency-cycle messages involving J40’s Type-C connector and USB PHYs:
/bus@0/padctl@3520000/ports/usb2-0:
Fixed dependency cycle(s) with
/bus@0/i2c@c240000/typec@8/connector@1
/bus@0/padctl@3520000/ports/usb3-1:
/bus@0/i2c@c240000/typec@8/connector@1:
I understand that these messages do not necessarily indicate an error by themselves, but I am including them because the affected port appears to correspond to connector@1, usb2-0, and usb3-1.
My Current Interpretation
It appears that when a USB 3 device is already connected to J40 during boot:
  • the USB 2 companion path initializes successfully,
  • the D435i falls back to USB 2 High-Speed,
  • the J40 SuperSpeed path may not be initialized or routed correctly,
  • after a subsequent detach/attach, the Type-C controller continues to detect the partner and reports host + source,
  • but the USB host controller receives no new USB enumeration event.
This makes me suspect a boot-time initialization or synchronization issue involving the J40 dual-role Type-C path, potentially around:
  • the USB 3 usb3-1 PHY,
  • Type-C SuperSpeed mux/switch state,
  • USB role-switch state,
  • UCSI / Type-C controller initialization,
  • or the handoff between firmware/bootloader and the Linux Tegra XUSB driver.
I do not yet know which component is responsible.
Expected Behavior
If a USB 3 camera is connected to J40 before boot, I would expect it to enumerate as USB 3.x after Linux starts, in the same way as when it is connected after boot.
Additionally, unplugging and reconnecting the camera should allow it to enumerate again without rebooting the Jetson.
Questions for NVIDIA
  1. Is this a known issue in Jetson Linux R39.2.1 / JetPack 7.2.1 with the J40 dual-role Type-C port?
  2. Is there a known issue with J40 usb3-1 initialization when a USB 3 device is already attached before boot?
  3. Is there a recommended way to reset only the J40 USB role / PHY / Type-C mux after Linux has booted, without resetting the entire 3610000.usb xHCI controller?
  4. Are there any debugfs, tracepoints, UCSI logs, or Tegra XUSB diagnostics that NVIDIA would recommend collecting to determine whether the failure occurs in the Type-C controller, role switch, SuperSpeed mux, or UPHY?
  5. Is there a device-tree or kernel workaround available for forcing J40 to operate as a fixed USB host if device/OTG functionality is not required?
I can provide complete good-boot and bad-boot dmesg logs if needed.
