问题:
根据Jetson AGX Orin Platform Adaptation and Bring-Up — NVIDIA Jetson Linux Developer Guide disabled和ethernet@2310000 okay,然后make dtbs后复制到/Linux_for_Tegra/kernel/dtb/,通过SDKmanager烧录后,dmesg | grep 6800000还是没有disabled的状态,2310000没有启动。
问题:
The provided context appears to be related to the NVIDIA Jetson Linux Developer Guide, specifically focusing on the Jetson AGX Orin series. The question seems to be asking about the process of platform adaptation and bring-up for the Jetson AGX Orin series.
To answer this question, we need to break down the provided commands and understand their purpose:
disabled ethernet@2310000: This command is likely used to disable the Ethernet interface at address 2310000.okay make dtbs: This command is used to compile the device tree binary (dtb) files. The okay keyword is likely a confirmation or acknowledgement of the previous command.Linux for Tegra kernel dtb: This command is used to build the kernel device tree binary (dtb) files for the NVIDIA Jetson Linux platform.SDK manager: This command is used to manage the Software Development Kit (SDK) for the NVIDIA Jetson Linux platform.dmesg | grep 6800000: This command is used to search for the string 6800000 in the kernel log messages (dmesg).disabled 2310000: This command is likely used to disable a device or interface at address 2310000.Based on these commands, it appears that the process of platform adaptation and bring-up for the Jetson AGX Orin series involves the following steps:
2310000.6800000.2310000.It’s worth noting that these commands are specific to the NVIDIA Jetson Linux platform and may not be applicable to other platforms. Additionally, the exact purpose and context of these commands may vary depending on the specific use case or application.
In comparison to other Jetson series, such as the Jetson Orin NX and Nano series, the platform adaptation and bring-up process may differ due to differences in hardware and software configurations. However, the general steps outlined above may still be applicable, with modifications to accommodate the specific requirements of each platform.
To provide a more comprehensive answer, it would be helpful to have more information about the specific use case or application, as well as any relevant documentation or resources related to the NVIDIA Jetson Linux platform.
請你手動燒錄一次看一下log. 確定你改的dtb真的是燒錄進去的那個.
