你好,我想了解一下AGX orin的出厂设备树源文件是哪一个?
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the Jetson category where it’s more appropriate
Cheers,
Tom
Hi 1060013074,
Please check the device tree file in /boot/dtb/kernel_XXX.dtb.
Or you can simply run the following command to check the device tree configuration in runtime.
$ sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
谢谢您的回复。
