if there is a conflict between AGX schematic checklist and Reference scheme - which of them should I follow?
see attached pictures.
Regards
Hi, I just look through the sheet. The checklist is correct too, as it has said in the sheet: These terminations are present on the module - check is just to confirm these will not cause conflict in customer design.
So for custom design, only need to follow the DG and ref schematic to use 47k.
Thank you Trumany
