Jetson Orin NX reference
I would like to get the reference carrier board schematic for Jetson Orin NX module but can’t find the Jetson Orin NX developer kit, instead, I can take reference from the Jetson Orin Nano developer kit.
  1. Can I verify all functions and performance of the Orin NX module with the Orin Nano developer kit?
  2. Which dev kit is the reference schematic for the customized carrier board for the Jetson Orin NX module?
  3. For our customized carrier board design using Jetson Orin NX 16GB, can I refer to documents of Jetson Orin Nano developer kit? Should I follow the schematic of Jetson AGX Orin developer kit?
  4. Our carrier board is based on the Jetson Xavier NX developer kit. Can I use Jetson Orin NX module on this carrier board?
Thanks,
Leo
They’re Pin and form-factor compatible, use ths same carrier board.
No specific one for Orin NX, you should check the design guide.
Check the design guide.
Jetson Orin NX & Jetson Orin Nano series modules are not pin-compatible with Jetson Xavier NX series modules, but you can design a carrier board for the I/Os they have in common, such that both modules are supported.
Thanks for the answer.
